What would be the best recommendation for an IEM at a price of around 50-60 euros.With strong bass, detailed analytical sound, good dynamics in Db, wide sound stage, QDC 2-pin connectors, crisp treble,a good stock cable. If there is such a model at all.Thx
That description mostly matches the Jade Audio (FiiO) JD7. It doesn't have QDC connectors on its cable (mmcx), and whether its stock cable is any good is a matter of opinion, more so than its sound characteristics.
@EMPORIUS Hmm - I can think of a few like that but all well over $100 or no longer available. Or both. Maybe the Final E3000? Cable isn't removable and is thin and plain-looking - but it also isn't tangly or noisy. IMHO a great choice in the $50 price range if you're willing to consider the bullet style.
+ WiFi…!!! With the usual ambitious Zishan features set. Per the (Chinese) manual: Airplay & UPnP (so you can cast from your laptop or phone to Z5 through WiFi, instead of Bluetooth), local Samba server (WiFi file transfer) and local MPD server (so you can use Z5 as a server playing tracks from the SD onto your phone, PC, etc. through an MPD-compatible app).
It appears that there is an Android app (apk side load).
No touch screen…. So to enter your WiFi credentials or SMB name/pwd for example, you have to use the keys to select a key on the screen keyboard…. Your SSID & Pwd better be short!
Interesting HW… but too expensive for what will most likely remain an experiment, with unstable fw and half-working features.
I'm looking at similar DAPs and most of them don't have such a button (they have vol/skip track though). Weird. Maybe you can use the power button for that?
€ 124,21 50%OFF | Original Iriver ICM30-FM Radio Recording Lossless Music Player DSD256 Vinyl Sound HIFI Fever Mp3 Walkman, https://a.aliexpress.com/_msKDtfQ
