Will update this thread from time to time when new DAPs are announced / leaked.
Lotoo PAW Gold
Highlights:
DSD support
22wh battery
USB 3.0
High precision clock
Powerful amp (500mW @ 32Ω per channel)
Parametric EQ
Sapphire glass
24k-gold plated controls
Release date: unknown
Claimed by the manufacturer to be a 'reference grade' player (and despite the hideous looks), this thing is gonna cost an arm and a leg (think USD $2000 level).
It's funny because Lotoo was a audio recorder manufacturer and virtually unknown in the head-fi community, and now they want to compete with iRiver...
P.S.: An interesting tidbit about Lotoo: A while ago HIFIMAN claimed Lotoo copied one of the original designs of the HM901 for one of the products (not this PAW Gold I think). You can read more about this
here (Chinese only).
Review from erji.net:
http://erji.net/read.php?tid=1656795
Opera Consonance Suzanne
Source:
http://opera-consonance.com/products/digital/Suzanne.html
Specifications: |
Full Music Format
| Ready for DSD 2.8M/5.6M.
Support DFF, FLAC, ALAC, WAV lossless formats.
| Strong Power Supply | We use the inductors power supply design. Make the headphone amplifier more powerful.
Suzanne can drive the high impedance headphone up to 600 ohm. | Removable battery | High capacity Li-on battery inside.
Easy to change the battery. | Large TF card | Standard 32GB TF card, up to 128GB. | Max output power | >135mW@16 ohm; >190mW@32 ohm | Sampling rate | PCM up to 32bit/384kHz, DSD up to DSD128(1bit/5.6M) | Display | 2.4 inch TFT | Headphone impedance | 16 – 600 ohm | Frequency response | 20 - 20kHz | THD+N | THD+N | S/N | >117dB | Battery capacity | 3300mAh (Charging time<4hrs) | Dimensions | 24*71*120mm (D*W*H) | Weight | 308g |
IHIFI770
http://www.i-hifi.com/770en.html
An interesting but lesser known budget DAP from Xuelin of
IHIFI960 fame, its equipped with a single WM8740 and comes with two POs with different sound signatures. According to
this review of an engineering sample, the sound is decent but the device suffers from crappy UI.
It costs RMB 999 and is available in China now.
QLS QA360
http://www.qlshifi.com/en/wzcapi/qa360.htm
Head-fi discussion thread:
http://www.head-fi.org/t/708636/qls-qa360-another-dsd-capable-dap
Copied from manufacturer's page:
Check out the QLS's website for pre-order info (see link above)
Aune M1
The M1 is a
16/44.1 WAV-only player from
Aune (Hifidiy). Comes in two versions: standard and deluxe version.
AFAIK the only difference between the two versions is the oscillator used.
Highlights:
Swappable DAC: Comes with PCM1793 at launch, may support ES9018, ES9023, AD1955, WM8741, TDA1543 in the future.
Swappable amp card, much like HIFIMAN
Pretty powerful amp: 700mW@32Ω
Good battery life: can drive HD650 for 8 hours (volume at 12 o' clock)
Low-jitter oscillator
Cons:
Support SD card up to 32G only (!)
No hi-res support
WAV-only...
HUM Pervasion
http://www.lyra-media.com/review_details.php?id=182
The Pervasion is a DAP of HUM, a company based in Hong Kong (I think). The Pervasion is equipped with Wolfson WM8741 and a
class A amp section but doesn't support hi-res music. Volume is digitally controlled by WM8741.
OS: Android
Battery life: 6 hours (WAV)
Screen: 4.3 inch IPS, 800 x 480
Connectivity: WIFI, Bluetooth
Storage: 8G of internal storage and Micro SD
Format: ALAC, FLAC, WAV, AIFF, AAC, MP3, APE of 16bit/44.1 - 48kHz
Input/Output: 3.5mm PO and LO
Dimension: 118 x 66.6 x 13.8 mm
Price is HKD $2680 (around USD $350). Availability is unknown.
More pics:
http://www.head-fi.org/t/720512/new-obscure-chinese-daps#post_10632691
Shozy Alien
http://item.taobao.com/item.htm?spm=a230r.1.14.1.ccy64D&id=39281503541&ns=1#detail
The Alien is a DAP without a screen from a virtually unknown company called Shozy. Comes with no internal storage but supports Micro SD up to 32GB. Plays FLAC/WAV up to 24/96. No other specs are known.
Ships August 1, 2014. Pre-order price is RMB 668 (USD $107) and $838 (USD $141) afterwards.
Musiland Monitor 04/06 MX
The latest USB DAC/amp combos from Musiland that double as DAPs
Both 04 and 06 support PCM up to 32/384 (WAV, FLAC, APE, MP3) and DSD.
An interesting feature found on them is a new digital audio transfer protocol called MULINK (developed by Musiland, I suppose. More info
here) that is capable of transferring native DSD64 and DSD128 to other MULINK-enabled devices.
The 06 MX uses PCM1798 for D/A conversion while the 04 MX has a PCM5102A.
Product links
06 MX:
http://www.musiland.cn/index.php/Product/show/id/207
04 MX:
http://www.musiland.cn/index.php/Product/show/id/208
Cayin N6
Highlights:
Async USB DAC
A separate D/A chip for DSD decoding.
Carbon fiber back panel, just like the AK240
More info will be available on September 15, 2014 and I will update the post accordingly.
Check out more pictures
here
Luxury and Precision LP5
From the designer of the Colorfly C4, now working for Luxury and Precision.
Highlights:
- Supports 32bit audio
- USB DAC supports 24/192
- DAC chip: AKM4414
- RCA digital out
There will be 2 versions: Gold and Silver.
Gold vs Silver
- Internal: 64G vs 32G internal storage
- Jitter 0.3ps vs 1.5ps
- Dual vs Single op-amp (1812O)
- Better caps on the Gold
- Price: RMB 6999 (USD 1141) vs 4999 (USD 815)
Not sure if DSD is supported
More pics
here
Shanling M3
For those who are not familiar with the company, Shanling is a HI-FI equipment designer and manufacturer (CD players, amps) based in Shenzhen, China.
An interesting thing about the design is the volume control which doubles as a control wheel. Shanling says the idea came from traditional lighters.
Specs:
- DAC chip: Cirrus Logic CS4398
- Cirrus Logic CS8422 for upsampling
- AD8610 and BUF634 per channel
- LPF: ES2664
- Display: 2.4 inch TFT LED
- Internal storage: 8G
- Supports microSD up to 64G
- Optical out
- Battery: 3600 maH, playtime up to 9 hours
- Dimension: 69 x 21 x 125.5 mm
- Weight:220g
- Color: black, silver
It seems the M3 is available now at the
Official Shanling Taobao Store for RMB 1980 (USD $323). You can see more pics there.
Eros H06
Eros is a sub brand of Aigo, which is a pretty well known manufacturer of an wide array consumer electronic devices such as cameras, MP3 players, GPS, tablets, audio recorders etc.
The H06 is Eros first DAP (and perhaps the very first product of any kind). Not much is known except that it will have 2 MicroSD card slots.
Source:
http://erji.net/read.php?tid=1715087&fpage=0&toread=&page=1
Colorfly New DAP
(Name not yet decided)
Source:
http://erji.net/read.php?tid=1722405
Specs haven't been published.
