FiiO M3K should fit your bill. I have one, & now my wife is using it almost everyday. Mind, if you have lots of songs, and want to navigate through all of them, it could be a PITA .
Thank you!
Tha k's I have been wanting to understand the difference, think maybe later this year, I might give it a try, can anyone say how bass roll off is compared to the Zishan dsd or dsdsF.Audio FA3S
And now I have both FA3 and FA3S, ready to be compared.
I tell the differences I found... The earphone is same, the good NiceHCK M6 (2dd, 4ba)
Volume: to achieve same sound level the FA3S requires higher volume set up, if FA3 is at 50 the FA3S requires 60, then power output is same, very high. It results in a better volume control, anyway above 80-85 it gets unbearable, "later" than FA3.
Digital filter: Both AKm and Cirrus dac have six setups but on FA3... cannot be changed! On FA3S while playing there is a short sound drop when changing the filter, that doesn't happen on FA3. Maybe a firmware iissue on FA3. On FA3S the different settings have very little effect, except the last one (low dispersion) that cuts a lot the highs. I can't tell how "low dispersion" affects the FA3 AK dac, as told... and I can't tell which set-up FA3 has been fixed to, I guess the first (sharp roll-off)
After various tries I choose the n.4 (short delay slow roll-off) but if someone secretely changes it, except the low dispersion, the day after I think I would not notice...
Battery life: I noticed the FA3S does not heats up as the FA3, it remain always cool despite being, like FA3, in Class A. FA3 lasts about 7h 30min, FA3S lasts about 20h 30min. Very good! It seem the new circuitry layout is more efficient (FA3 - single dac AKm 4497 / FA3S - double dac CS43198)
Sound: Not huge difference, everything is "a bit" FA3 has more rumbly bass, FA3S goes deeper sub-bass. FA3 mids highs smoothly warmer, FA3S highs more opened and sparkling, more detailed and analytical.
I like them both, soundwise I would not know which one to grab. Summing, the pros of one vs. the other...
FA3 vs FA3S:
- Velvet sound (as per its dac AKm 4497)
FA3S vs FA3:
- Clear neutral sound, deeper sub-bass (though bass roll-off is still present, bass amount is about the same)
- Better volume control
- Battery life, the greater upgrade
- and about 40 $ cheaper
So, overall, the FA3S is an improved product over the FA3, at a lower price (even if the FLODER view typo in the main menu is still here...))
My friends, any bugdet mp3 player with bluetooth for pairing with tws? I have been looking goods from Benjie and Ruizu, and I have no clear if they are working fine in that way. Thanks in advance.
I was thinking in players lower in price. It's just for my ride to work free of wires. I already have hi-res portable gear for wired earphones. So I thought on something cheaper. Thank you.Tempotec V1A?
I was thinking in players lower in price. It's just for my ride to work free of wires. I already have hi-res portable gear for wired earphones. So I thought in something cheaper. Thank you.
The issue with Benjie, Ruizu et al. is that the Bluetooth function may not necessarily be very well implemented, which is going to suck for TWS. The Hiby R2 is the most affordable Bluetooth-equipped DAP from a reputable brand that I know of, maybe you could look into that
For those who are not familiar with the company, Shanling is a HI-FI equipment designer and manufacturer (CD players, amps) based in Shenzhen, China.
Hi! I just discoveres this amazing site!I can always predict when it will happen. It happens when you change it to and English language then either reboot or power on/off the device.
Which Tempotec do you have? I still mainly use either my Fiio M5 or Shanling M0 as they sound better than this M200.....
regarding the walnut player and zishans. They have a private facebook user group primarily based out of the phillipines. Lots of good hacks
I bought this tiny DAP over christmas as an impulse but something to replace my M0
Been pleasantly surprised with the sound and size. Bought the non-bluetooth version for $79.
some pro reviewer here should review one.
https://www.amazon.com/gp/product/B07TWQZY45/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&ps
Follow the linkhello All
can anyone tell me if the Acmee MF-01 has had a firmware update so it can read more than one level of folder ??
cheers
