funkymartyn
Gueray at about £25.....or the Akamate at £50 from china , forfilled by Amazon..so hopefully could return if no good etc
Looks interesting. $499 is kind of rough, though. Even if it had stellar sound, the rest of it doesn’t justify that kind of price (imho). Still, if you get it, let us know how it sounds.Hey All-
There is a Chinese seller on Ebay who has already put up for sale the new Zishan DSDs Dual Versions (Ak4497, Ak4499)
The Dsd Ak4497 2x is listed at $199 US
And the Ak4499 2x listed at $499 US
Although they aren't as DIY Budget-friendly for modding (risk of damage lost of investment modding because heftier cost for stock model) it's still can be considered a ”bargain” to some for it's specs especially if it lives up to past Zishan experience with those who love it's legendary sound-budget-ratio.
There is pics of the Dual Ak4497 but none for the Dual Ak4499 which are truly balanced. However, off the bat it looks like the battery should have been bigger for more hrs of playtime. Listed its only 4hrs which is kind of bad
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/274273652726
The display of the JWD JWM-115 is better than that of the Tempotec, it is a better quality panel, it is brighter and better protected. I also think it's more accurate and logical to use, it works more like a smartphone. However, it is heavier and a bit bigger, although, also, the construction looks more solid. As for the advantages of the Variations V1-A, it is the double SD card slot, has more power, works as a DAC and can be used as a transport. But it's also more expensive...
The display of the JWD JWM-115 ....
Playlists. Another way is to only index one card and keep the other card for full albums and such and not index those. That way, you can find the full albums in the sd folder and use the player like a shuffle. Anyways, that’s how I do itThe V1 (without analog) TempoTec is down at 71.20 right now, while the JWD is at 68 ... not that different anymore
Enjoying the heck out of the V1A, though I only used the analog part only briefly to test if it works.
One problem I keep having with all players (and I honestly don't see a practical solution), with all that extra disc space now, the amount of music I can lug around becomes unmanagable, I keep scrolling forever to find what i look for / feel like ... anyone found a better way to tackle that?
Please advise what is better to buy
in terms QUALITY of SOUND -
1. jwm-115
or usb-dac for smartphone -
2. tempotec sonata idsd ?
And why a comparison only with x2 and tempotek?
How is the sound compared to other players - acme, zishan, etc.?
Tempotec Sonata iDSD Plus
I'm overworked and trying to make comparisons with similar devices. Acmee MF-01 is much more powerful and has no touch screen, comparisons would only be in sound and it is not easy to compare. The sound of each is different, more spectacular and spacious the jwm-115, while the MF-01 is very special and natural, an organic sound that does not surprise, but that can be liked very much for its sincerity.
I'm talking about the regular version without "PLUS" (the same stuffing, but with one DAC and one amplifier) )
There is an opportunity to buy it.
Those. You still advise that it is better to buy tempotec idsd than jwm-115?Yes, I know. But if you can buy the plus version, it's a great option, even used as a DAC connected to the PC. The balanced output is very good.
