funkymartyn
Hi normally you have to choose folders, not songs. Then open folder and play all.....etc
For all those who wonder... The QNGEE X2 has been surpassed, by this practical and simple DAP.
Here is my humble opinion about the JWD JWM-115:
https://www.head-fi.org/showcase/jwd-jwm-115.24197/reviews#item-review-23250
I modded HD-X10, replace every big capacitor, swap SMD chip to OPA1612, swap big opamp to OPA1622 (best combo opamp from TI), but dropped it and one of the capacitor comes out due to my sloppy soldering. Now it's like a decoration that I hang on the wall to remind myself of the first time I try to mod something haha.I just broke my Ziku HD-X10.
On its third drop, it was a concrete floor where it took a slide afterwards. The metal body wasn't damaged other than minor paint scratches.
I actually permanently damaged it after opening it a few times. I didn't realize the battery was simply soldered to the motherboard and the wires could easily come loose. One wire popped off the board. I then screwed everything back together without soldering it back as I don't know how to do that.
I heard a noise come from the device while in another room. I then opened it up and took off the second wire in case it was some sort of reaction due to not being fully connected.
I don't recommend opening this device or opamp rolling unless you know how to pull an opamp without damaging the legs as no extender can be used.
The battery is glued to the back casing and board and when you pull open the device the glued battery is attached to the back casing and becomes loose.
The Opamp inside is:
5532D
JRC
J099A
It sounds phenomenal with the Blon 01.
The only player with BT 5 I have seen so far is the Yescool M200, reviewed by vortex a bit further up. The thing looks nice, so I caved in and mine is on the way seems that AliExpress is the only source. For smaller there is the TempoTec Variations V1A ... but that’s BT4.xFrom above thread..I use the xduoo x3 at the min. Which is great with the sound, two sd cards, etc....but ?????
Just found this one too...anybody have it.
AKAMATE MP3 Player, 3.5 Inch Touch Display Bluetooth 5.0 MP3 Music Players 8GB, 1080P HD Video, One Click Recording, Built-in Speaker, HiFi Lossless Sound, E-Book, Support up to 128GB (Black) https://www.amazon.co.uk/dp/B0829QB8CQ/ref=cm_sw_r_cp_apa_i_bMzsEbEJAC9F6
