mordy
- Aug 8, 2010
What are the functions of all the toggle switches?I think one is to switch between speakers and headphones and the other is the impedance switch.
The picture are fantastic and this amp looks awesome. The work on the chassis is really professional lookingFirst Infinity for sale is now complete! @DecentLevi
This one has the tube rolling add-on. Here with KT66's and 6J5G's
This is going off on my Oblivion...What are the functions of all the toggle switches?
- will you replace embossed labels ?
Guess my goldfish is safe then because I'm a fast paced bowler (cricketer).I'm a somewhat fast paced tube roller. I have no need to replace the embossed labels.
When you plug your turntable, do you have a dedicated Phono input stage with transformer ?In his words...
I can include a toggle switch at the back to select between RCA and XLR. That way you don't have to unplug anything.
Without the switch some signal would leak out the RCA inputs if you use the XLR for example.
WOW!! To Infinity.. and beyond.. in search of new civilizations, the starship enterprise never stays still.
Beautiful brushed aluminium front and perfectly complemented by matt black top and side plates.. what's not to like . I imagine it sounds as good as it looks, in which case it must sound awesome!
I have the GOTL with the 6/12/25V switch in the back. Perhaps it looks better like that, but I would much rather have it in front because it is not possible to see it when the amp is on a rack, and it is also very difficult to reach it when the amp is rack mounted. Not to speak about burning yourself (OUCH!) reaching for the switch and tubes blown up because I forgot to look - no, make that feel, for the position of the switch.I have a phono stage. The Elekit TU-8500 is a preamp / phono stage. I left my Avid Pellar phono stage back in Sydney with the Rega RP8.
I did think about having the switch in the front but that will spoil the looks. Besides I don't think I'll be switching between the dac and turntable very often. Yggdrasil has it's power switch at the back.
GOTL has the 6/12/25 volt switch behind. Some things we have to live with being put behind.
This is exactly the kind of technical/functional design done without taking care of different usage. This is what i also have in CTH both on/off switch and also 6.3/12.6 on the back... As i do not see the warning about heating voltage i've sometime over heated some tube fortunately seing glow very bright alert me... I finally added a small label warning of heating voltage...I have the GOTL with the 6/12/25V switch in the back. Perhaps it looks better like that, but I would much rather have it in front because it is not possible to see it when the amp is on a rack, and it is also very difficult to reach it when the amp is rack mounted. Not to speak about burning yourself (OUCH!) reaching for the switch and tubes blown up because I forgot to look - no, make that feel, for the position of the switch.
Voltage switch in the back guarantees no accidents due to trying to change impedance, and by mistake switching to 25V and frying your 6SN7...I have the GOTL with the 6/12/25V switch in the back. Perhaps it looks better like that, but I would much rather have it in front because it is not possible to see it when the amp is on a rack, and it is also very difficult to reach it when the amp is rack mounted. Not to speak about burning yourself (OUCH!) reaching for the switch and tubes blown up because I forgot to look - no, make that feel, for the position of the switch.
