Oblivion | UltraSonic Studios
Apr 9, 2024 at 6:56 AM Post #7,471 of 7,481
Hope you're still enjoying your Ultrasonic Studio amp(s). I have here the following tubes on Odyssey:-
Cossor 53ku, Telefunken EL11 and RT EL39. My Sennheiser HD800 sound just like a top of the line headphone. :)
Still loving my Telly like it was new.
High impedance headphones really scale nicely with tube amps. Especially when you switch it to the high-impedance output of the amp.
Apr 9, 2024 at 11:10 AM Post #7,472 of 7,481
2 years 7 months now. It arrived on the 13th Aug 2021. The day before our Covid lockdown started. Looking at all the excitement and leadups' to actually getting Odyssey, it's a wonderful experience. It's still my best sounding tube amp.
Not having Tomas here is just a big lost.
Apr 9, 2024 at 12:20 PM Post #7,473 of 7,481
Yeah not only he's an amazing person, but I used to look forward to the end of the month when he unveils a new build. It was so cool to see everyone's amp and unique features its had.
Apr 9, 2024 at 10:48 PM Post #7,474 of 7,481
This is why I have good hopes for the ModHouse Tungsten. It is high impedance but also has a very low sensitivity. Should be even quieter than the HE-6 SE and hopefully better in technicalities.
My Odyssey too has an impedance switch (125 ohm) and ultra linear. I like ultra linear more. I find it gives more "kick".
I had also wanted the LCD-4 then they stopped production just before I got the amp....
But this amp was conceived in my mind to drive the HE-6 SE. Maybe Tungsten will be an even better pairing and I will stop my headphone hunting.
It is the time I upgrade my DAC, even though with the Gungnir MB I am quite satisfied. Maybe something with "hotter" outputs. I was meant to be Audio-GD HE-7, but then I felt too pleased with the sound and was spending less and less time listening.
Apr 11, 2024 at 5:57 PM Post #7,476 of 7,481
Hi,
https://streamable.com/czqv0t
I have noticed a strange sound, not sure if it is coming from the transformer or something else. I swapped the KT170 positions.
This is HE6se on the 8 Ohm impedance at around 75% volume open.
What is it? Do I need to worry?
Is it the ringing sound that comes on occasionally? Is it with every song? May not be the amp. Switch source and see.
Apr 11, 2024 at 6:38 PM Post #7,477 of 7,481
It is the vibrating / clicking sound.
When I switched off the channel, it stopped vibrating. So I assume it is coming from the transformer or some related components - definitely not from the tubes as I switched those off.
Apr 11, 2024 at 7:04 PM Post #7,478 of 7,481
You will do a few troubleshooting. Change KT170 to something else. Change HE6SE V2 to another headphone.
That clicking sound do you hear it only when music is playing? Switch to triode mode. Don't use UL. If you have a feedback switch, switch it off.
Apr 27, 2024 at 8:20 PM Post #7,479 of 7,481
As lovely sounding as the day when I first listen with it. @Slade01 waiting for your impressions.
Apr 28, 2024 at 5:36 AM Post #7,481 of 7,481
Incredible pairing with HD800. Wide soundstage, clarity and saturated tones. It was worth elevating it to the top of the rack for some tube rolling.
At the moment, I have Marconi 6AV6 and Siemens EL81.
Tomas' amps are magical when you pair the high-z output and a high-z HP such as your HD800.
I got similar results with my Beyer T1 and ZMF Atrium closed. Personally the amp improve the atriums' performance level close to that of uber TOTL HPs.
