SonicTrance
Member of the Trade: Custom Amp Builder
I see you have plenty of gear to keep you busy @UntilThen Happy listening!
Hi everybody!
I’ve read this thread and have a question. It was said many times that these amps are not typical tube amps. Soundstage is not enlarged, treble is not smoothed, bass is more controlled, no tube rolling. It is closer to solid state amp.
So the question is: what is the point of tubes in Citadel? If somebody like SS amp sound, why not to buy SS amp? I assume there is something that Citadel does better than typical solid state. What is it?
Thank you @BzzzzzT for coming here with your expertise! Very good post!This is a good question and it all boils down to harmonics. Our brains are very sensitive to harmonics. Tubes produce a 2nd order harmonic distortion that mimics how we hear real sounds. Solid state also produces some harmonics, but these are mostly 3rd order, and this does not naturally occur in nature.
So the question is how does this work. To give a direct answer, these added 2nd order harmonics make it easier for our brain to perceive the sound. This is because all sounds in our physical world produce harmonics, and this creates the timbre of a sound. Timbre is the qualities of a sound that distinguishes it from other sounds of the same pitch and volume. Say a cello or a violin playing the same note at the same pitch. The harmonics of both will be different and we will know that these are different instruments. Our ear has evolved to be extremely sensitive to harmonic as our hunter-gatherer ancestors needed to be able to distinguish certain sounds to survive.
Solid state does not mimic the natural world and creates mostly odd order harmonics, which are not found in the natural world. This creates a flatter stereo image. When we add harmonics it actually makes it easier for our brain to perceive and process the sound. In an audio amplifier this will translate to a more realistic and three dimensional sound. This also makes it easier to actually perceive detail because the added harmonics make the sound more recognizable to our brain.
Tomas's amps use a circuit that addresses the many unique requirements of using tubes. Solid state is used to drive the tubes and output transformers to their most optimal and linear condition. In the old days, this was not possible. This gives you less smearing of the sound and distortion, because the circuit is not sagging under load and is maintaining a consistent operation, when driving the tubes. You get the accurate sound of solid state with the harmonics that makes it easier for the brain to perceive sound; creating the 3d and more natural timbre that tubes are known for.
An analogy for harmonics is an atom composed of a nucleus surrounded by a whirling vortex of vibration called the electron cloud. The comparative solidarity of the nucleus is like the fundamental; the electron cloud is like the harmonics.
The first mode is called the fundamental frequency or first partial, or alternatively the first harmonic. The fundamental frequency is of vital importance because it determines the pitch of the note we hear. But in addition to the fundamental, there are other frequencies produced by other modes of vibration. These accompany the fundamental although they are not so distinct. The second mode, for example corresponding to halves, produces a frequency double that of the first. Consequently it is called the second partial. The 3rd produces a frequency three times that of the first harmonic; this being called the third partial, and so on. Theoretically, this extends into infinity, with each fractional part contributing it's own frequency to the mix of frequencies that we call tone. Timbre is complex and our ears have evolved to be very sensitive to harmonics. Tubes present sound in a way that makes it easier for our brain to physically process.
Sorry for the long winded explanation, but this is the reason why tubes sound different and whey people tend to favor them for listening to music and for various production purposes.
Have a look at this post from me yesterday. Cannot double post so have a peep there when you have time and tell me what you thang?
https://www.head-fi.org/threads/1101-audio-custom-crafted-headphone-amps.919425/post-16109211
Yes some people don't realise that when they say they like a euphonic sound, say, what they are really liking is distortion. It's like saying that you like the sound of the Gibson Les Paul sound which has a sustained distorted sound which is characteristic. After all that is the sound of electric guitars, they would not sound the same driven by a clean sounding hifi amp.
BTW I've just checked out your posts on the HE1000SE thread.. and I think it's fair to say you like it a bit . (I'm assuming you still do lol). So I'm still looking forward to your impressions when you finally get to hear it with Oblivion.
This is a very true statement which was also in my mind for some time. I guess Eternity will be my final test to understand how much I love distortion.
Also the lower output impedance and nimble circuit gives better frequency response. Some examples of more euphonic amps would be OTL circuits and traditional SET amps.
That's the clever part of these amps. Not having a transformer in OTL amps, or having anything between the output tubes and the output signal in OCL amps also for example, would appear to be ideal because nothing interferes with the audio signal, but then you have the problem of controlling the impedance, obviously the lower the better. By turning that idea on its head and putting in a transformer in the output stage in parafeed mode you can have the best of both worlds, good control over impedance and at the same time there is little to interfere with the signal. As Sonic has said even a modest output transformer in parafeed mode will do all that is necessary.
The balance has been perfectly struck between power requirements and control over impedance and parasitics.
