xtiva
Wouldn't know what the actual conductor diameter is.. would guess about half the cable diameter? 0.9mmTo be clear, I'm talking about wire only, without shielding and sleeves.
Holy cow!!! That’s freakin’ thick! Me love thick cables my DHC C15 S-mod (I know it’s quite a mouthful) is already at 15.3 AWG and super thick, can’t imagine how thick this monster 13 AWG cable is.So about 4x13awg that's ****in massive - I like it
It has been clarified since then, that this measurement was with shielding and sleeve.Holy cow!!! That’s freakin’ thick! Me love thick cables my DHC C15 S-mod (I know it’s quite a mouthful) is already at 15.3 AWG and super thick, can’t imagine how thick this monster 13 AWG cable is.
Would anyone have an opinion on whether feedback switch would still do anything to the sound, even on an amp without TR/UL mode? I'm having Tomas convert my Finyssey to an Odyssey for several reasons, and he said feedback mode is only useful if you have TR/UL mode, though I'm wondering if it may still yield interesting results.
Single ended or push pull? It depends on the kind of feedback I imagine. The speakers you have will be part of the equation too. I have only ever heard one amp with variable feedback. The Cary 805 lets you add up to 10db of global feedback. I found about 2-3db of feedback tightened up the bass and gave a more defined soundstage on the big Spendor monitors, SP100 I think. Zero feedback was certainly richer and rounder. Too much feedback made the sound progressively closed in. That amp uses either an 845 or 211 triode. Global feedback lowers harmonic distortion and increases the damping factor. Comparatively massive amounts of global negative feedback is what leads to vanishingly low distortion and super high damping factor of solid state amps. A lot of people say that too much global negative feedback makes a tube amp too solid state sounding. On the other hand some speakers require more damping factor to get good bass.Would anyone have an opinion on whether feedback switch would still do anything to the sound, even on an amp without TR/UL mode? I'm having Tomas convert my Finyssey to an Odyssey for several reasons, and he said feedback mode is only useful if you have TR/UL mode, though I'm wondering if it may still yield interesting results.
After having already converted the output section to auto-bias last year (this is when the Sowtwers came in and the name changed from Infinity to Finyssey), I basically just need the input tube section to be converted to auto-bias as well. As Tomas said this would be to:How is the conversion done? With a new chassis and reusing whatever parts possible? Odyssey in my mind, is the most beautiful sounding tube amp I've ever heard.
I'll leave this for Tomas to answer. I believe it's an SE amp. Stock output tubes are still KT66 pentodes, and input is 6SN7 triodes, and I would be using mainly with headphones. I now have the HEDD Audio HEDDphone. It sounds like feedback mode (hopefully variable gain not a switch) would be a nice option, but I'll wait for his feedback about any benefit of having this without TR/UL mode.Single ended or push pull? It depends on the kind of feedback I imagine. The speakers you have will be part of the equation too. I have only ever heard one amp with variable feedback. The Cary 805 lets you add up to 10db of global feedback. I found about 2-3db of feedback tightened up the bass and gave a more defined soundstage on the big Spendor monitors, SP100 I think. Zero feedback was certainly richer and rounder. Too much feedback made the sound progressively closed in. That amp uses either an 845 or 211 triode. Global feedback lowers harmonic distortion and increases the damping factor. Comparatively massive amounts of global negative feedback is what leads to vanishingly low distortion and super high damping factor of solid state amps. A lot of people say that too much global negative feedback makes a tube amp too solid state sounding. On the other hand some speakers require more damping factor to get good bass.
Triodes, including strapped triodes, are inherently pretty low in distortion so global negative feedback can be optional. It's pretty much essential if you are running pentode mode. I'm not sure it would be too easy to just add a variable global feedback to an existing circuit. Pretty sure the circuit needs to be made with feedback in mind otherwise it can lead to oscillations. Think I read that "higher quality" transformers allow you to use more feedback.
Right, I keep forgetting this is a headphone board lol. I don't think damping factor is important at all for headphones. Another thing global negative feedback does is reduce gain. I don't trust hifi amps that use 12ax7 input tubes. The only reason to use such a high gain tube is to apply lots of negative feedback. The only reason to use a ton of feedback is to use its distortion lowering capabilities like a sledgehammer. Measures well but... eh. Might as well use a solid state amp at that point.After having already converted the output section to auto-bias last year (this is when the Sowtwers came in and the name changed from Infinity to Finyssey), I basically just need the input tube section to be converted to auto-bias as well. As Tomas said this would be to:
"get rid of the input stage gyrators, the grid drivers and the B- power supply and all the adjustments.
Then replace that with resistor loads for the driver tube anodes and cathode bias for the input tubes."
The manually adjustable input tube section of my amp developed unstable performance glitches after using apparently untested tubes a while back, so I sent it back to Sweden for another do-over. We may also find a way of further reducing the hum, and upgrading the initial audio input wire. The HEDDphone does completely reduce the hum to a barely noticeable amount, but lowering it would allow other headphones to play nice as well.
Interesting. The two h/p/a that I owned / own which ‘normally’ call for 12AX7 tubes - Quicksilver Audio, Icon Audio HP8 - sounded / sound better to me with 5751, 12AT7 tubes. More ‘dynamic headroom’, less ‘compression’.Right, I keep forgetting this is a headphone board lol. I don't think damping factor is important at all for headphones. Another thing global negative feedback does is reduce gain. I don't trust hifi amps that use 12ax7 input tubes. The only reason to use such a high gain tube is to apply lots of negative feedback. The only reason to use a ton of feedback is to use its distortion lowering capabilities like a sledgehammer. Measures well but... eh. Might as well use a solid state amp at that point.
Same here, I used TS5751's for ages until I found equally, or even better 12Ax7's, Philips, were fantastic. Now I replaced the Philips with a 12AT7, the Brimar. I do think that with the right 12Ax7 though they are at a very high level, I changed my mind after hearing the best there was.Interesting. The two h/p/a that I owned / own which ‘normally’ call for 12AX7 tubes - Quicksilver Audio, Icon Audio HP8 - sounded / sound better to me with 5751, 12AT7 tubes. More ‘dynamic headroom’, less ‘compression’.
