That adapter would need to have a resistor inside it to drop the voltage down to 4V. Would work but could get very hot inside the adapter. Not recommended.
So no one has an opinion on these crystal white Ascension speakers that are specially made for tube amps? 95dB is very efficient in my book. 10" woofers !
Must be as many ways to clean a record as there are tube rolling combos in all of UT's amps Personally, I clean the record in a DIY ultrasonic machine and then rinse/vacuum/dry on a VPI HW-17. The above thread has made me consider also doing a pre-clean on the HW-17. I have about 30 new records that I'm waiting for a rainy day here to clean.
It sounds great, but @leftside recently had an LCR phono custom-made, this is a more esoteric type of tube phono, the bee's knees, tricky to design, requires specific tubes and custom chokes. I collected some E55L tubes, maybe seven or eight pairs, great for the LCR phono, it's on "the list" of things to do, but first tube DAC.
Mick from Supratek is also a great guy to deal with - as with the custom amp builders on here. We've become friends as he is also a downhill mountain biker.
