hpamdr
- Feb 11, 2015
Do you use a thermal camera to see if some parts ca get too hot ?Burn-in is subjective to me. Some say so many hours for this and so many hours for that.. Impossible to say IMO. There's not many components inside the amp that would require burn-in. The electrolytic caps needs to settle but there're only four of them in the amp and none is in the signal path.
I always run the amps, with signal, for 48 hours before shipping. I've had a little extra time with this one so it has over 50 hours already. I do this to build up heat inside the amp and stress it to see if there's gonna be a component failure.
Does eternity/infinity needs a fan underneath ?
