ieee754
- Nov 11, 2013
Is there any quality loss if I connect O2 with another amp? I'd like to use my ODAC but it's in combo with O2 and I don't want to mess with internal electronics.
If your amp section is powered off, the amp line out works as a dac only. There should be no quality loss.
Does it really work? After turning off amp I don't hear anything from headphones. Shouldn't it play at a very low volume?
It works! But I had to connect headphones to line-in of the amp, and it plays only at low/moderate level. Why do I need O2 then?![]()
Well, my stand alone odac also works when I plug in my headphones, but it does not have nearly enough power to actually drive headphones to optimal listening levels. I find that my iems do well with the ODAC alone and adjusting the volume in windows to 100% produces a decent volume. Which amp are you planning to use with your DAC?
I used Sennheiser Momentums which are pretty efficient and the volume level of ODAC is listenable, but it lacks bass a bit. I'm not sure about new amp, I'm interested in getting Hifiman headphones (now waiting to see reviews and measurements of HE-560) which require a lot of power so I'm asking just in case O2 was not enough. Do you know any O2-like (in terms of transparency) amp that could drive even HE-6?
Unfortunately, I do not have any experience with Hifiman products aside from my short lived possession of the HE-300 (sold it). As far as amps go, I only own the O2 and NFB-12.1. Both are efficient to drive HD600 and Denon 2k. Hopefully someone else may point you in the right direction in terms of amps for HE-6.
That's interesting that you're O2 was capable of driving the HD600. Do you know what gain setting that was with? I ask because I quite fancy a pair of HD600's in future.
Ok, thanks anyway, I didn't know that this is possible to use ODAC directly from the combo.
By the way, is there any reason to think that O2 won't be able to drive headphones like HE-500 even at high volume? I did the math and it seems that O2 with 613mW at 33ohms headphone impedance is able to drive any headphone with efficiency above 87.5 dB/mW to peak SPL of 115dB without clipping, here is how I calculated it:
E - headphone efficiency in dB
P - power from amplifier (for O2 it's 613)
10^((115 - E)/10) = P
115 - E = 10 * log(P)
E = 115 - 10 * log(P) = 115 - 10 * log(613) = 115 - 27,87 = 87,13
I was told in another thread that O2 can't drive HE-500 at high volume, but it seems that to reach 115 SPL only 398mW is required, is there some property of O2 that makes it worth getting better amp?
I clipped my O2 myself to 1x/2.5x gain and use 1x gain with my HD600. I am among many that find the O2 sufficient in driving the HD600. Although I do prefer my NFB 12.1 for the HD600 since it adds a little darkness to the sound.
That's good to know. I use 1x/3x gains so I'd get away with it. Thanks for the info.
Of course the gain depends on your source also. I find that I need higher gain if I use it with my cellphone, and less if I use it with the Odac. How far into the future will this investment be? :]
