Solrighal
- Jan 27, 2005
nah. you just get stoned to death. by headfi police.
Ah, I remember those days with fondness.
[deleted]
Playback Options:
Audio Output set to WASAPI
WASAPI Settings: Device Default or ODAC, Check Open Device for Exclusive Access, BitDepth set to Automatic,
Buffering set to 100ms default. If you have pops or clicks set lower...on one system this is set to 25ms. If you have issues at the default 100ms setting to higher times makes this worse.
All the other stuff on the Options Page is pretty much default.
With windows there are other WIN7 settings that need to be setup correctly as well but I don't know the MAC equivelents.
On a PC when the little ICON in the upper right side of the JRiver screen turns "Blue" you basically have achieved BITPERFECT with the JRiver player....that is what the source is is the source out....
That said the OS settings may or may not impact these.
Glad you liking the O2 and ODAC....for the bucks you cant beat it....for sure.
All the best
Alex
For the Mac, output is set to ODAC. Let the different bit rates default. Any further question, you can PM me.
I've got my Mac set to ODAC in Sound Preferences. In Audio Midi Setup I've set output to 2ch/24bit @ 44.1khz. I had intended to set this to 96khz but it won't stick. Is this correct?
Mine seems to work. I'm still running the latest version of Mountain Lion if it makes any difference. Mavericks still seems to have too many issues for me to upgrade. XD
Speaking of which, this thread might come in handy to some people who use OS X.
http://www.head-fi.org/t/539740/mac-os-x-music-players-alternatives-to-itunes
My ODAC doesn't look like that in the left pane. I don't have the 64ch option. In the right pane you have it set to 16bit, not 24bit. I can make my screen look like yours when the player is stopped but as soon as I restart it goes back to 44.1khz, irrespective of whether I set it to 2ch-16bit or 2ch-24bit. Hmm...
Is soundflower something you installed yourself? Who made your ODAC?
I dunno what the 64ch thing is for.
Yes, Soundflower is a separate program I installed myself. I use it to capture audio from the computer to the computer (e.g. play audio in iTunes and record it with Audacity).
