NuPrime DAC-10H - Desktop DAC and Headphone Amp
Jun 18, 2016 at 9:13 AM Post #77 of 152
Sorry I haven't heard the Hilo in a long time. The Matrix X-Sabre is about to be superseded with an upgaded model coming very soon, so I'm not sure I'd buy the original new at this point. But a used one makes sense, it's still a great DAC. Matrix is a little more exciting, rich midrange and some emphasis down low. The NuPrime is neutral to a fault so the rest of your system better be ready for that.
Jun 18, 2016 at 10:30 AM Post #78 of 152
Well, i have Ultrasone Sig Pro cans, they can add some fun factor.
Didn't know that Matrix preparin new DAC. That should be very interesting. There is any info about upcoming device?
Jun 23, 2016 at 12:34 AM Post #82 of 152
I forgot to ask how Nuprimes usb input sounds against external converter. Is it ok, mediocre, or somewhere worse than all of it?
I feel it is quite good - not easily improved unless you spring for a really nice DDC. For example my Stello U3 does not improve anything, and may actually make it worse. My Resonessence Concero used as a USB to SPDIF converter sounds very slightly different (due to their proprietary digital filter perhaps?) but not necessarily any better. I have to use my Audiophileo 1 with PurePower, or the new Singxer SU-1, to find a small improvement. Honestly it's not really worth messing with unless you have very nice headphones/speakers and intend to do very critical listening... which means the stock USB is very good indeed.
Jun 26, 2016 at 2:28 AM Post #83 of 152
project86 What if compare Nuprime 10h to Yulong D8 II? I read both reviews, and it seems, that they should sound very similar. Does Nuprime's double price worth the sonic difference between them?
I almost sold all my previous gears and think to end up with Yulong as all in one solution. Metrum Musette+ Violectric v200 was not my cup of tea afterall. This combo way too dark and restricted.
Jun 26, 2016 at 1:56 PM Post #84 of 152
Around here, the Yulong is $1200 and the NuPrime is $1800. So there is a price difference but definitely not double/half price.
I do feel the NuPrime is the better device by a reasonable margin. It's worth it for me. The amp section is good enough to be the only amp you might own, while with the Yulong I can see wanting to eventually add a dedicated amp. The NuPrime looks better, has more transparent sound, and even works as a preamp for analog sources. The only reason you might go Yulong is to get a smoother, more tame high end.
Jun 26, 2016 at 7:25 PM Post #85 of 152
Thank you for info.
Jul 1, 2016 at 4:54 AM Post #86 of 152
At this price range, the nuprime is really facing some tough competition. let alone pro audio companies putting out hifi-oriented products, like the Prism Sound Callia. Traditional companies also have good offerings. The returning Audio Alchemy's DDP-1 is also a DAC-amp-preamp. W4S Dac2 DSD SE is also very competitive at the near 2000usd range. Really hard to make a decision when they are not available for direct comparison at a demo room.
Jul 21, 2016 at 8:11 PM Post #89 of 152
I'm still loving my DAC-10H. I think the price per value is terrific. I went to Capital Audio Fest recently. Seems like there are a number of products in the same market...all in one pre/DAC/HP amp. I heard the Callia by Prism with an LCD-2 and there was another similar product-Brooklyn DAC-HP amp-preamp .
I have not had the chance to hear Questyle. I'm curious how the DAC-1OH compares to the Questyle CMA 800i? They seem similarly priced.
