cleg
- Oct 14, 2011
My impressions on Kaiser Encore
Congratulations on your new Noble's! Ear-tips are very important and my advice is that you patiently try all sorts of tips. Comply's are great, but take out some of the "air"! Silicone bring out better low-end and so on! Take time to make sure that you have placed the Noble's right! You will be rewarded!Just picked up a pair of these, having convinced myself that high end IEMs are my preferred long term listening option.
Everything said about the look and feel of these is spot on and the packaging etc is great. There's just one thing, NONE of the enclosed tips fit me, NONE!!!! So having spent 1p shy of £1,700 the first evening with my new Noble's was soundless - a seriously downbeat start. The weird thing is I don't think I have unusual ears and have had no trouble getting a decent fit with my other IEMs, most recently my Westone W60s, where the second largest foam tips (the red ones) worked fine.
Complys ordered, now just have to wait...
C
i suppose BA is less prone to change from burn ins, and on the cable side i use ares 2+ from effect audioDoes anyone know if it requires a break in period and if so how long? Also I'm finding the trebles just a little aggressive and little bit of listening fatigue over extended periods (also depends on recording). What cables are people using on this... I've actually ordered of a DHC 8 strand TRRS 4.4mm.
Anyone have this combo?
Really Weird. At almost 300 hours the treble fatigue and aggressiveness seems to be gone.i suppose BA is less prone to change from burn ins, and on the cable side i use ares 2+ from effect audio
my suggestion would be you getting acquainted enough with the sound so you dont feel the significance anymoreReally Weird. At almost 300 hours the treble fatigue and aggressiveness seems to be gone.
try laying off the IEM a week or so and get back to it, you will return your perspectives (maybe)
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
