swissheadphonelover
Order for Niimbus US5 placed, no confirmed delivery date, waiting and looking forward
Didn’t you already buy a us4 from a friend?I will test US5 Pro by the end of June.
Ok.Yes but i want to know if there any difference in sound between models.
I believe that the US 5 would be the same as the US 4+, but that that US 5 additionally possesses that 4.4 mm connector, and does not possess that relay volume control, that the US 4+, and that the US 5 Pro, possesses.Ok.
I thought the us5 is the us4 internals and specs (except for additional input and output (4.4mm)) , and the us5 pro was us4+
Or at least that was what i believed was announced
Either way, let us know
YesI believe that the US 5 would be the same as the US 4+, but that that US 5 additionally possesses that 4.4 mm connector, and does not possess that relay volume control, that the US 4+, and that the US 5 Pro, possesses.
It was my first blind purchase at this level….and I love it!!!Will be my first niimbus, „blind buy“ based on the information in this thread.
That‘s very nice to hear, US 5 has also remote with motorized potentiometer instead of relay volume control.Yes
As i understand it *that does not go against how you explained it (I believe):
Us4 to us5 is 4.4 connector and extra rca inputs
Us4+ to us5 pro 4.4 connector
Hence us5 to us 5 pro gives you relay volume (and remote
Next, you may need to look at what you you need to sell to afford the susvara.
The only think i would have liked is the remote so sometimes i think maybe i should have bought the us4+ but hey I can’t have everything and i have already out layed a lot. Having said that….a remote would have been a good bonus instead of me having to lean forward and manually rotate the volume knob as often as I doIt was my first blind purchase at this level….and I love it!!!
Ahhh… i did not it was motorisedThat‘s very nice to hear, US 5 has also remote with motorized potentiometer instead of relay volume control.
I believe that that US 5 possesses all of the features that that US 4+ previously had possessed.Yes
Hence us5 to us 5 pro gives you relay volume (and remote)
Yes. The buttons on the back don’t bother me at allI believe that that US 5 possesses all of the features that that US 4+ previously had possessed.
Consequently, I believe that that US 5 also possesses that remote, that control for the balance for the amplifier, and those buttons that are within the front panel, that are for changing the inputs, and that are for changing the outputs.
Lucky you share you opinion with the rest of us please.I will test US5 Pro by the end of June.
