Hello Everybody.
Normally I don´t answer to posts like „Why do they use cheapo Neutrik XLR sockets instead of outstanding ones from the xxx brand”.
But sometime I feel I have to adjust things …
Neutrik is THE supplier for high quality XLR sockets and connectors. Among others they also offer RCA, phone jacks of outstanding quality.
Besides that they offer their products for a reasonable price.
Most of these connectors are directly mounted on the PCB (one contact / one resistance) which is a smart solution compared to
those sockets which need a wire (resistance) to be soldered to the connector (resistance) and then soldered to the PCB (resistance).
Not taking into account the different materials and how they match or eventually don’t …
Also a wire is always a source of faults and needs more production time.
The best connecting point is the one which is not existing !!
And don´t tell me about silver solder.
This can be seen at your Jeweler but not in electronic manufacturing because the melting point is over 950 degrees Celsius (1750 degrees Fahrenheit).
Did you know that only three countries in this world are not part of the SI-system. These are
Liberia,
Myanmar and
USA.
For electronic works silver is only a fraction of the solder, about 2 - 6 % - not more!
Ours is “Sn95,5Ag3,8Cu0,65”, meaning 95,5 % tin, 3,8 % Silver, 0,65 % Copper.
And yes, Neutrik uses Brass contacts instead of others who may use Copper contacts.
But as everybody knows, electricity is really clever and takes the way of the lowest resistance.
And that is the coating of the contacts which is Silver or Gold in case of Neutrik.
The purpose of the basic contact material is only to give Gold or Silver a surface.
Table of conductance (sorry, in German, but those who are really interested may google):
Silver offers the best conductance (much better - about 300 % (!!) - than the fashion material Rhodium !!!) but it will oxidize and becomes black.
This doesn´t matter that much as silver oxide has nearly the same conductance, unfortunately it is not looking like that.
Copper contacts will also oxide but then become green with a really high resistance.
So we are using gold plated contacts which are always looking good
See the picture how Neutrik contacts mate, can you imagine something better ?
And, sorry, I give a damn on
“super heat resistant liquid crystal polymer resin and a nonresonant nylon/fiberglass housing containing … Piezo Ceramic Damping Material.
Special nonmagnetic stainless steel plates that are incorporated into the piezo compound construction (original text from Furutech)”
I even don´t know what that means nor what it is good for. And I am not going to waste my time on learning more about that.
Like nearly everybody busy in serious and reliable electronics production we trust in Neutrik´s fiber-filled
XLR housings and gold plated contacts which withstand ten-thousands of connecting cycles,
proved in our laboratories and testing facilities.
Others may save money by using Chinese copies or waste money by using piezo compound constructions …
