PinkFloyd
- Jan 13, 2009
Hi Simon,
Zobel fitted, removed lamps (replaced with ferrite inductors or zero ohm links) removed both input and output caps and yes IMO (to my ears) there is quite a vast improvement. The zobel is probably unnecessary with FET opamps so if you just whip out all three LM6171's and remove the output caps you're good to go. I find something like an opa 627 is good in the rail splitter.
Mike.
Originally Posted by l_simon_l Wow mike, this sounds exciting. What mods are done to your WNA in addition to changing the opamp to AD8065 and getting rid of output and input caps? Zobel Network? Removed lamps? My WNA is currently all stock. Is the difference significant? If so, I just might have to make use of my soldering iron again |
Hi Simon,
Mike.
