I've got it running in both my amp
and Steviedvd's MKl amp at the moment with no output caps, no input caps or other **** in the signal path..... It's by far "my" favourite in the WNA but that doesn't necessarily mean a lot as ears are as unique as fingerprints and we all hear things differently... some may love it, some may like it and others may despise it but It sure is worth giving it a try.
[/QUOTE=PinkFloyd]
If as you mentioned before it's more spacious then it's likely to float my boat.
Originally Posted by PinkFloyd
Listening to Steviedvd's "Barebones" 228 MKl WNA right now (after spending the afternoon and evening faffing about with it) and Frank Sinatra sounds like he's in the same room with me (dunno if that's good or bad!) I'll leave you to comment on it Steve and if it doesn't suit your ears then I'll retrofit the LM6171, input caps, trimpots, 10M resistors et al.
You can also try the AD8065, OPA627 and many more chips Steve without the need for the signal strangling in / out caps.... They are direct drop in (plug and play) chips, try them all!
Mike.
If I can opamp roll to try other amps then I'm techy enough for that, even the trimpot idea was freaking me out in case I blew up some headphones.
I've got some OPA627, AD843 & AD847 here as well as a few from my SM3 doing nothing (don't have the numbers of the others to hand) but I'll be pleased to give the 228 an extended tryout first.
BTW what was the problem with my WNA was it a blown component? I'll send a cheque to cover postage and parts etc but we can deal with that via PM.
Steve
