New! WNA MKll Head-amp kit.
Jul 10, 2006 at 6:54 PM Post #751 of 763
PinkFloyd
You'll notice the rapid ones are 0.1% and not 0.5%
Jan 28, 2007 at 1:53 PM Post #754 of 763
FritzS
Originally Posted by biovizier /img/forum/go_quote.gif
I preferred both the ad847 and the ad8065 to the ad843 - though all were better than the lm6171 - in the head amp at least. I only have the WNA headamp left now.
Now I found the LME49710 (single version from LM4562)
http://www.national.com/pf/LM/LME49710.html
http://cache.national.com/ds/LM/LME49710.pdf
and ordered some LME49710 to test them in WNA MKII
It's a exciting game LME49710 and LM4562 vs. AD843, OP275, AD823, ect
May 8, 2007 at 8:11 AM Post #755 of 763
FritzS
Hi,
now I use three LME49710 in WNA MKII in my modified WNA MKII, instead of AD843 (amp) / LM6171 (railsplitter).
First I cannot hear any difference between. First I heared with senn HD 600.
I think for exact compare I must use two WNA's so I can change very quick between to hear very small differences
Some of CD/SACD's I used:
KODO (Japan SONY), Concord Jazz SACD sampler, PF Final Cut, ....
May 15, 2007 at 9:12 AM Post #756 of 763
FritzS
Hi,
Hi,
now I am going back to AD843 (amp) / LM6171 (railsplitter)
It's imagination from me or not - with LME49710 and K 701 I feel the trap is littleness sharper .........
music SACD Ray Brown - Summer Wind - Live At The Loa
I test the AD843 in railsplitter - it oscillates
Jun 25, 2007 at 2:41 PM Post #757 of 763
FritzS
Hi,
Hi,,
now I run two AD847 in my modified WNA MKII (with AKG K701 and Marantz SA 7001 KI)
My first experience:
More punch
More "metal" than "soft" in "brass"
Music come to the fore
Not for quiet sound level - here is the AD843 "king"
My opinion - this statements are subjektiv - objective are only ABX tests with two similar amps but different OPA's and a ABX switcher.
But this statement is be true for the most of the DIY test's ..... or?
Has anyone test the AD847 (singel) or AD827 (dual) too?
Jul 9, 2007 at 9:11 AM Post #758 of 763
FritzS
We ignore Linear Technology Linear Technology - Linear Home Page
Now I use two LT1056 in place of the both AD847
There are very little differences ....
First test - from the first tick I hear - I am snoopy why after a burning in time
Treble (cymbals) are a little bit softer, silkier, darker, more natural
Micro Dynamics - more than AD847 - more in background too.
2nd & 3rd test - as far as I can see the LT1056 is a "big player" like AD843 too
Natural, detailled sound with good micro dynamics, open wide and deep stage.
I think one must be changed: The WNA design use a ferrite bead between the output of the OPA and the powerstage. This is not calculated for other OPA's. The datasheet suggestions of LT1056 use a little cap 10 ... 33 pF in NFB:
"When the feedback around the op amp is resistive (RF), a
pole will be created with RF, the source resistance and
capacitance (RS, CS), and the amplifier input capacitance
(CIN ≈ 4pF). In low closed-loop gain configurations and
with RS and RF in the kilohm range, this pole can create
excess phase shift and even oscillation. A small capacitor
(CF) in parallel with RF eliminates this problem. With RS
(CS + CIN) = RFCF, the effect of the feedback pole is
completely removed."
But I dont hear oscillation in audible range or distortion. Only very good sound
And all this with an "old design" 5.5 MHz, 14V/us OP - silmilar to the OPA602
Next I will test LT1022 if I get some samples
Speed are not essential
Gain Bandwidth / Slew Rate
LT1056 5.5MHz 14V/us
LT1022 8.5MHz 23V/us
OPA602 6.5MHz 35V/us
AD847 50 MHz 300V/us
AD845 16 MHz 100V/us
AD843 34 MHz 250V/us
LM6171 100MHz 3600V/us
AD817AN 50 MHz 350V/us
Dec 31, 2009 at 4:02 PM Post #759 of 763
FritzS
I want to use my WNA MKII on a second place in my house - with the old Philips CD650 too.
Headphone is the 25 Ohm impedance Denon AH D7000
Last testing OPA was the LME49710NA - it plays very good - but I am not totally happy with it.
So I searched further, after the LME49710NA I put in ...
OPA134 similar, but a bit more musically than the LME49710NA
OPA604 similar to the OPA134, but a bit more muted
LM6171 that's is - very detailed, more punch, the D7000 likes the LM6171 in the WNA MKII
My special mods in the WNA you found here
blue-danube DIY audio - WNA MKII Modifications
I hear music if I write this text - the longer, the better the music are played, the WNA and CD640 burning in - they had a longer time out before
Music:
Audio - Digital Masters I / Sara K. + some Chesky & Telarc (Classic) samplers
Audio, das Magazin für Hifi, High End, Surround und Musik - AUDIO 01/10
The Klezmatics - Live in Berlin
The Klezmatics - Grammy Award Winning Music
Neil Diamond - Jonathan Livingston Seagull
Paul Simon - Graceland
PS: My opinion - this statements are subjektiv - objective are only ABX tests with two similar amps but different OPA's and a ABX switcher.
May 13, 2012 at 9:43 AM Post #760 of 763
FritzS
[size=x-small]Hi,
before I put my WNA MKII into my depot, I changed the OPA's
before AD847, and now OPA134 ..... and wow it tops my "green" Solo with OPA LME49720HA instead of the AD823.
It's only an imagination? [/size]
[size=x-small]The WNA MKII sounds a bit more naturally, warmer
Solo inclines sometimes to a little bit sharp tails ...
The WNA MKII source impedance: 15 OHM (series resistor in the output)
Solo use 33 OHM
Tested with my AKG Q701 (I know some prefer 120 OHM as source impedance with this headphone)[/size]
[size=x-small]The next step are[/size]
[size=x-small]now with OPA627 .. and the violins shines ....[/size]
[size=x-small]and my Denon AH D 7000 like it too [/size]
[size=x-small]Max Bruch, Violinkonzerte Nr. 1 & 2, Salavatore Accardo, Gewandhausorchster Leipzig, Kurt Masur, CD
Max Bruch, Violinkonzerte Nr. 1 & 3, Tortsen Janicke, Gürzenich Orchester, Markus Stenz, SACD
and the both BlackGates NX 1000 uF 25V are re-burned in now (the sigle caps in signal path) [/size]
more about
http://rockgrotto.proboards.com/index.cgi?board=m&action=display&thread=8052
[size=x-small]PS: For two month I had an AKG K1000 as guest - now I must then give back - the K1000 is an very gread headphone! [/size]
Apr 22, 2016 at 11:01 AM Post #761 of 763
FritzS
Now I was snoopy and ordered a pair of the new Burson Supreme Sound Opamp V5 S for my headphone amp WNA MKII.
Before I used OPA627 (after a lot of others) with best performance.
First short hearing test, my feeling the Supreme Sound Opamp V5 S surpassing the OPA627 in details of music.
In Ray-Brown-Summerwinds - Li'l darling (tr. 3) I hear each hair of the brushes more than with other OPAs.
Its hard to compare them, I don't have two ident WNA MKII, so I need to swap the OPAs for comparing.
The headphone I use for comparing is the AKG K812 Pro.
Next days I will spend more time for comparing.
About Burson Supreme Sound Opamp V5 S
http://www.ssaudio.com.au/products/supreme-sound-opamp-v5/
http://www.bursonaudio.com/products/supreme-sound-opamp-v5/
Nov 5, 2018 at 2:05 AM Post #762 of 763
FritzS
Now I test AD797 opamps (biased into class-A as all others in this place). They are different to OPA627 and offers a bit more fine details and less sharpness with AKG K812 Pro (in some music tracks hearable).
I had thought about oscillation before without compensation of AD797. But it works well without additional caps. AD797 have a bit of a diva.
AD797 now the best OPA in WNA MKII.
Oct 1, 2021 at 10:44 AM Post #763 of 763
FritzS
After AD797 I returned to OPA134 with good result.
BUT - now I use a pair of Burson V6 Vivid single.
The best sound I had ever heard with (now old) WNA MKII!
My first impression, very detailed, yet musical, no noticeable sibilants, airy, space between musicians, very detailed, good micro dynamic, relaxed listening with the AKG K812.
Music: PinkFloyd - The Final Cut; Loreena McKennitt - Live at the Royal Albert Hall.
The playback chain is now fully discrete, Marantz also uses discrete amplifiers in the analog section of the SA 7001 KI CD/SACD player.
