BrokenEnglish
- Feb 2, 2004
hi jose,
nice to read from another "uncapped" wna! i described the same symptoms of crackling while turning the volco after removing the input caps. it's neither related to plastic or metal knobs, nor to incomplete grounding of the pot. most likely it's caused by dc-offset returned to the input, as dr. white told me some time ago. i was hoping to get rid of it with the 10m-resistor and 100k-trimpot mod, but couldn't test it so far. stay tuned.. i'll try it soon.
mike... do you think, one could use the 10m/100k "caps-free" mod in combination with output caps while leaving the input caps out? ah... i'll try it anyway...
btw... i finished my dual-voltage psu (basically 2 tweaked TREADs with electronic ripple and noise rejection, currently 2*14v DC) to bypass the wna-railsplitter. after 2hs of usage there were no audible advances. but... BUT... now i'm able to increase the rail capacitance without the risk of further transistor death. i started with 1000µf electrolytic, bypassed with 10µf tantalum, bypassed with 0.082 + 0.022µf fkps. very intense bass, nice highs. i'll give it a week of burn in before i report back.
Originally Posted by spendorspain Drawbacks? Only a very minor and I hope not worrying: when I rotate the volume control fully counterclockwise (I always do that before turning the amp off or when changing interconnects) there is a faint crackling, but only at the very end, never in the useful range of pot. I now simply stop their rotation a little before it ends (anyway, at this point the sound level can be -60/70 dB, I guess). |
hi jose,
Originally Posted by PinkFloyd to cut it short you can use the LM6171 with 10M resistor and trimpot only if you leave the input caps in place.... |
