Originally Posted by spendorspain
Hi
I’d like to post my opinion on 330k mod because it’s different. My modded WNA hp amp sounded great, as I said in my previous post, but as listening hours passed I began to feel a certain loss of extreme highs, like a subtle but noticeable filtering of the “air” of the recordings. It appeared only after a long (two months!) break-in period when, I guess, the sonic personality of the new components fully developed. Perhaps there was simply a mismatch between the modded amp and my very mellow-sounding audio system (Meridian 206DS CD, Van den Hul “The First” carbon cable and Grado HP-2 with flat earpads, which reportedly sound a little dark and very different to the brighter RS-1 or SR-325). Looking for an explanation, I searched the Web and read a lot of posts in this and other forums. All info pointed to the 330k resistors because several head-fiers described this mod as “smooth sounding” or giving more “soul and warmth” to 6171 IC (perhaps the Grado HP-2 have “soul” enough on their own ). Moreover, I’d used AudioNote tantalum resistors, also said to have a sweet sound. So, I decide to open the case and unsolder them, with amazing results. The highs went back and the missing air and space are there again without any audible side-effects in the rest of frequency range. I’d like to know if somebody have similar experiences with the 330k mod, although perhaps it’s only a mismatch with my own system.
The 330K certainly does "warm" the sound up a tad giving the impression of a smoother overall sound with deeper bass and more musicality overall. Yes, you
do trade off a bit of air (everything in audio is unfortunately compromised by one thing or another, you generally can't have your cake and eat it) but you benefit as the LM6171 becomes less sterile, clinical and analytical. I liked the 330K mod when I was using polyester caps in my last amp (the 100nF ones) but, as I say in the post above, the sound with the 330K
and polypropylene caps in place doesn't have the same bite and grunt as the amp with polyester caps and 330K did.
My newly acquired SR-325i may be throwing me off course a little here but I distinctly remember them as sounding pretty forward and aggressive with my last (WNA fitted with polyester caps and 330K) with the new WNA (polypropylene and 330K) they sound beautiful.... a match made in heaven.
However my HD-600's, which sounded
perfect driven by the polyester / 330K WNA now sound slightly rolled off and positively syrupy driven by the polypropylene / 330K latest WNA..... so, yes, I totally agree that the 330K plays quite a big part in the sonic signature of the amp but so do the 100nF capacitors! 330K and polyester gave perfect synergy with the HD-600 whereas 330K and polypropylene makes them sound
too chocolaty. 330K and polyester made the 325i's sound forward, aggressive and "toppy" whereas 330K and polypropylene make them sound absolutely heavenly.
It's a weird old game but the beauty of DIY is that you can tune the amp to your own requirements....... I'll be trying the WNA without the 330K but with the polyprops in place this weekend..... I've got a feeling the combo of polyprop
and 330K may account for the "smoothness" with the HD-600 but I don't wan't the SR 325I's reverting back to sounding "in yer face" at the same time, I love the WNA / HD 6** combo and would like to get good synergy with
both the Grado and Sennheiser 'phones........ a good challenge for the weekend!
Regarding the last post of Mike and others from Udo, and my own preference for a very open and transparent sound, I’m thinking about removing the polypropylene input caps to see (hear?) if this improves the sound, but I’d like to do that in a safe way. Could you explain how to measure DC offset at output of CD player with a voltmeter? I suppose I have to touch the inner tube ("live") of RCA socket with the red probe and the outer ring ("ground") of socket with the black probe, in both channels and with my multimeter set to measure mV DC (in my case in its "< 2V DC" setting ). Is this correct? Is the measurement made with music playing or perhaps in "pause"?.
What would be a safe value of DC offset, if present, in order to connect the CD player to the WNA hp amp with no input capacitors? Can this value drift in certain circumstances (e.g.: be a safe value today but larger and dangerous in other moment)?
I always check DC offset from the source at the input of the amp with a CD in the CDP on pause. Set your voltmeter to DC and onto the 200mV range. Probe the phono socket (inside your amp) thus:
Black probe (com) to phono socket ground and red probe (V) to phono socket signal...... IMO anything under 25mV is acceptable and you're safe to dispense with input caps (jumper over C1) My CD17 measures 0.00mV on both channels though my Denon CDP measures 4.1mV L/H & - 2.1mV R/H both are ok to use the amp without input caps (as are the vast majority of CD sources)
The WNA kit
only employs input caps to make it bullet proof for use with
every source under the sun..... there may be 2% of sources that output DC so the caps are fitted as a "better safe than sorry" measure..... a bullet proof safety net if you like. Sure the amp will sound a lot better without them in the circuit but check your sources offset before binning them.
Another thing you may want to try is replacing the 47K input resistor with a 10K resistor. Dr. White commented on this on the MKl and I quote:
"Lowering the input impedance to 10k will give ( theoretically ) lower noise and will also reduce the output offset with the LM6171, but not enough so you can dispense with the output caps. The component values that I choose for my designs are a compromise which will work satisfactorily with the widest range of attached equipment. I generally use 47k input impedance because that'll pretty much work with anything. For my personal stuff I always use 10k. That's the beauty of DIY you can tweak your gear to suit yourself."
You'll note Dr. white also says " The component values that I choose for my designs are a compromise which will work satisfactorily with the widest range of attached equipment" in 99% of cases it's probably perfectly OK to dispense with input caps and use 10K input resistors etc. He's providing a kit which has to work first time every time with
all equipment.......
It's not for me to suggest you remove these safety barriers but the performance of the amp is certainly a lot better with them removed but, if you do decide to remove them, ensure your source has minimal DC (only really crap / obsolete / faulty gear will have a massive DC output.... 99% of it should be fine
As to the Output caps..... I'd recommend leaving them in........ I tried the 10M resistor and trimpot and couldn't hear a lot of difference but the input caps are well worth removing
I’d also like to comment the musical results of using a WNA Cascode PSU instead of the switching-mode “wallwart” supplied as standard. As “1up” and “Captain” have said before, it is worthwhile. It improves dynamics and detail, lowers the noise almost to inaudibility and makes big orchestral climaxes clearer and effortless. The sound is more natural, realistic and “free”. Now, without the 330k resistors and with Black Gates output caps and the Cascode PSU, the WNA amp sounds better than ever… until the next upgrade arrives (perhaps the removal of input caps or the increase of quiescent current of output transistors).
I must get round to auditioning a cascode PSU, sounds good, I'm still using the linear open frame calex PSU and it rocks my boat
As always, I’m afraid this post is too long, but I hope you can explain the doubts I have.
No post is too long when It's interesting Jose and your first three posts have been very interesting and informative.... please keep them coming
All the best.
Mike.
