rlw6534
Is it possible the nwa105 also has a roll off?
It doesn't have the USB DAC function or I would test for you.
I think rlw6534 saying his were fine to him and now showing his chart shows same, its your sensitive ears that are right by the looks of it.
Quick how to:
Install REW. Put the device (A306) in USB DAC mode connected to your computer (you have to open the Walkman player and select the mode in addition to the popup from USB connect). Connect the 3.5 mm to your computer line in.
Start REW and select "Preferences", upper right.
My setup screen with input and output:
Select "Calibrate soundcard". Select next until this screen. Increase volume on A306 to get close to -12 dBFS:
Select next again as needed until the sweep runs and you will get this screen. Select "All SPL" on the graph options.
It’s this your a306?? If yes it looks perfectAfter Calibration
Then select the All SPL tab
This look right ?
Yes my A307, assuming I've followed guide correctly
i'm 95% sure that my unit is also like this, but i will order 3.5-3.5mm cable and measure it just in case )psikey you’d better keep this one close to you, it’s as rare as a diamond.
ladies and gentlemen here we the first correctly measuring a300 series Walkman
If you can please provide: where it’s been purchased, which serial batch and firmware build number? Might help us narrow down
No the A105 never had a roll off there was plenty of bass in that model ...I am very curious to test the A306 now my ears are not perfect but if it sounds different from A105 i will instantly know .Is it possible the nwa105 also has a roll off?
A 45, A55, A105 I've had them all and my A306 sounds simular. Sounds better actually but very similar. They've all been a bit on the bright side. But although clear sounding I can't call mine bass light. It has weight and rumble when it is supposed to. Idk what's going on. I read some Japanese reviews last night and no one mentioned low bass.
It's all very strange. But like I said it sounds very similar to a105, which also sounded different than the 507 model.
