Ryokan
The capped one couldn't drive a moped.
Couldn't pull the skin off a rice pudding.
Is that what it's all about, pushing people to buy overseas so they have no warranty
Very good point - never thought of it like that.
adb shell cmd overlay enable com.android.internal.systemui.navbar.gestural
Just got my A306 today from Japan and wanted to share a few things I've discovered, as well as provide another example of a lack of low-end.
First, for those of you not familiar with Android, there are three types of navigation bar (the three symbols on the bottom of the screen). The A300 ships with the old three-button style and doesn't have a setting to enable the new gesture-based navigation. However, the functionality still exists, albeit behind an ADB command. To switch to the new gesture style navigation you can run the following command:
Given the limited screen space on the A300, I think the more minimal gesture style navigation is really helpful. Here's a photo of it in action:
It does look like restarting the device slightly miscalculates the bottom area, but this is easily fixable by rotating the device to landscape and back again.
A few pages back I think someone was asking about setting an accent color, which is part of the Material You design system on Android 12 and 13. Unfortunately I haven't found a way to set the accent color based on the wallpaper; it appears that the dynamic color engine is completely missing from the OS.
Finally, I noticed that music from the headphone jack felt flat, almost as if it was being played through a phone's speaker. I confirmed that it wasn't me just being crazy by using an Apple USB C to headphone adapter and confirming that the low-end was much more noticeable via the adapter. I've enabled the Equalizer using the "Excited" preset which seems to alleviate most of the issue. Still, I find it strange that out of the box music sounds lifeless compared to a basic $9 DAC plugged into the same device. I tested at volume level 80 on my DT 770 PRO 80 Ohm.
S01-20002xxWhat range is your serial? Mine is quite early batch i think; Sr # S0110000xx
S01-20002xx
After trying a few different listening devices (WH-1000XM3 via passive, Mackie CR3, Apple EarPods) I'm starting to think the issue is related to power output. I've only been able to reproduce the flat sound via my DT 770 PRO. I wouldn't have anticipated that the Japanese A300 would have issues with 80 ohm headphones, but it's starting to feel like it does.
Nope, all via the headphone jack. Returning is an option (albeit a painful one given I imported it from Japan), but I think I want to try with an easier to drive set of headphones before declaring it mechanically defective. Either that or get a scientific confirmation that some models exhibit the behavior and some don't.100XM3, CR3 and Earpods - are you using them via bluetooth?
Great post, precisely the comparison I was looking for.Been A-B testing across a range of my familiar tracks today including some DSD, 96 & 192 FLAC and some MQA.
I've concentrated today on just using Walkman app with own files with my Sony IER-M9 which I consider currently my best, most revealing IEM's. I have only been using 3.5mm, not comparing to 1AM2 4.4mm balanced.
- To volume match my Japanese A307 & WM1AM2 the 1AM2 had to be 4-5 volume steps higher.
- To me the A307 is a bit brighter but also has a bit more bass impact & forward mids.
- Listening to song below for 1st 10s or so repeatedly, instrument placement/distinction/clarity seems same but 1AM2 sounds like its in a slightly bigger, more expansive space with a bit more decay of instruments, more lingering echo.
- In Walkman music app, both are snappy in operation, but the A300 OS/SOC is noticeably faster with third party streaming apps and faster USB & wireless speeds. ZX700 series should be even faster operation with its 8 cores vs 4 cores of the A300 series (but also lower battery life).
- A300 series battery life is much better than A100 & ZX500 series and I'd say will satisfy most people now, but of course any Sony Sound tweaks & live streaming a music service by third party app over Wi-Fi will maybe give you 10hrs (was about 5-6 from my experience with older series (I use only Direct mode).
I can honestly say if I lost my 1AM2 I'd be perfectly happy sticking with just the A307 using my M9's via 3.5mm.
The 1AM2 is going to handle more demanding ear/headphones with its much higher output 4.4mm balanced and having high gain too. And as you would expect for price difference, audio quality is that bit better with 1AM2. The 1AM2 via balanced has no real stereo crosstalk if your sensitive to that, I'm not noticing via 3.5mm with either DAP.
If your on a budget or want a small player with the Sony house sound/great Sound Quality, with decent battery life for the size of the player using Android, this is fabulous.
I suspect if your happy with lower battery life, the ZX700 series is best of all worlds being faster & having balanced but in a less pocket friendly size/weight than the A300 series, yet having near same components as WM MK2 series and bit smaller/lighter and cheaper than that.
I've not tried any BT audio yet, but Wi-Fi streaming stability seems fine for me at home.
NOTE: Those more hardcore audiophiles with Golden/Younger ears may be able to hear difference better than I can so as always, have to listen for yourself.
I understand that measuring audio output accurately is incredibly difficult and requires special equipment, but I figured a basic "record through my computer's microphone port" comparison of the default setting, ClearAudio+, and via the Apple USB C adapter might be useful.
Looking at this, it appears that at the same volume, ClearAudio+ might be making everything a touch louder, which is why it sounds more appealing than with it off. This also appears to be the case with the Apple USB C adapter. So I might be just falling into the trap of "louder is better" and tricking myself into thinking that the default doesn't sound good. (That being said, I have decent hearing and even at 80 the default sound is pretty quiet.)
Interesting, I missed that info.According to sony's own page yes.I don't expect any meaniful changes, but I thought it might help with the wee bit of screen noise, hiss I get.
Just tried it, it actually seems to have a bit wider stage with the balanced 3.5. I'll listen more tonight as my mind could be playing tricks on me but that's how it sounds.
