rlw6534
Ahh thank you, that’s good to hear.
+1 that Japanese versions do have the Google Play Store
Another member here shared this link which can be applied to the A306:Just had one delivered today, any tips or tricks? Already updated to Android 13, and decreased the text and display settings.
reading this im not sure why you got the walkman?Hi everyone! First time lurker here.
I just recently purchased a US NW-A306 after having a Japanese A55 for about 1.5 years, and I don't know whether to love it or hate it (leaning on love lol)
My setup is a B&W Px7 S2, Linsoul KZ ZS10 Pro, Apple USB-C to 3.5mm, and the headphones that came with the A55.
My biggest issue is using the Px7 via USB-C cable. Whenever I use the Walkman Music app, after giving it permission to use the B&W, any flac that has a sample rate of 44.1 or 88.2khz sound choppy and a bit faster, whereas 48 or 96khz sounds perfectly normal. Even the preloaded songs have the same issue. These headphones have a built in DAC if used via USB-C.
It works fine via BT and the USB-C to 3.5mm cable attached to Apple's USB-C to 3.5mm adapter. For some reason the B&W USB-C to 3.5mm sounds very low when plugged in to any device.
Enter UAPP. This app is amazing btw...
So the exact same issue happens with this app but if I turn on Upsample, it works like a charm and works with other apps like Spotify and Bandcamp. If I don't activate UAPP, other apps will have lower audio quality and volume.
Either way, I can't get the Walkman app to work with most of my songs.
Is there a setting I'm missing or are the B&W the issue here?
Also, I just want to say a huge thanks to everyone here for all the tips mentioned, such as how to debloat the OS, change the navigation buttons, minimize settings, and recommending the Niagara launcher and UAPP.
yesI’m stupid but can you use this with an external usb c Dac dongle?
Given it works well with the USB-C ato 3.5mm adapter and it works when UAPP upscales, it looks like an issue with the Px7 DAC. Have you tried the USB cable in your computer in direct (WASAPI, ASIO) mode?Hi everyone! First time lurker here.
I haven’t. I’ll give that a try. Thanks for the response!Given it works well with the USB-C ato 3.5mm adapter and it works when UAPP upscales, it looks like an issue with the Px7 DAC. Have you tried the USB cable in your computer in direct (WASAPI, ASIO) mode?
Do you mean the WF-1000X M5? They always sound the same, no matter the source. But there are differences in the codec.How is the sound quality of xm5 tws with A306 compare to using xm5 tws with phone? Anybody any reviews please? I want to buy xm5 but need to make sure about this. Because Bluetooth has its own DACs and no contributions from the audio player you are using. Can we use A306 equalizer or DSEE Ultimate?
Yeah Android phone I mean. Thanks for your reply. I got my queries cleared! I would rather invest in good IEM. Just that I wanted a wireless mode but again, I cant utilize A306's full potentialDo you mean the WF-1000X M5? They always sound the same, no matter the source. But there are differences in the codec.
What phone? Android?
iOS does not support lossless audio codecs (LDAC, LHDC and so on), so if you compare the A300 Series to an iPhone, you will be able to hear an difference. But there will be no difference to an Android Phone.
The WF-1000X M5 are consumer oriented earphones. They key points are features and comfort, not sound quality. There are wired earphones for less than 50$ that easily beat the WF-1000X M5, so even if the A300 Series would have an advantage, you would not be able to hear it, as the earphone are just not good enough.
