New Sony Walkman NW-A300 Series (Android 12)
Jun 22, 2023 at 2:50 AM Post #3,331 of 4,198
Do you hear a big difference between LDAC and aptx adaptive? I havent been really able to at all. I thought about getting a blue tooth rig but my phones battery life is such trash i almost never use it for music ha
Only used LDAC or Apples AAC
Jun 25, 2023 at 5:55 PM Post #3,333 of 4,198
i have to say i normally would listen to music on direct source and i have been with the sony but i feel like it lacks volume in the lower end (yes ive updated etc). really noticeable in the car using the aux plug.
anyway i decided to mess with the eq, ive also turned on dc linear. have to say it sounds much better now. like really good. i dont like clear audio as i think it sounds echoey. here are my settings, i started on excited and then tailored it to be less bassy using custom
Jun 26, 2023 at 5:00 PM Post #3,335 of 4,198
Hello, i just bought NW - A300 series Model YY 1301B1, chinese version, i cant install youtube music. How to solve it ?
its need to flash it or how ?
If returning it isn't an option you can try to update to international firmware (which has Google Play Store). Turn off wifi and copy the firmware file to internal storage root directory and a prompt should pop up to install. Be aware that if you later perform an OTA, it will likely revert back to Chinese firmware, so you will have to update manually using the procedure above.
http://info.update.sony.net/PA001/N...0001/NW-A300Series_0000_V1_01_04_NW_WM_FW.UPG
You can always find the latest firmware link in this xml file:
https://info.update.sony.net/PA001/NW-A300Series_0000/info/info.xml
Jun 27, 2023 at 3:18 PM Post #3,336 of 4,198
i already try
but could not update
it say Try again later, if there is not enough free space, remove unnecessary files on the internal storage
Jun 27, 2023 at 4:53 PM Post #3,337 of 4,198
i already try
How much free space do you have in internal memory (not SD Card)?
Jun 27, 2023 at 10:46 PM Post #3,338 of 4,198
Apologies if this had been asked. I’ve just taken delivery of a Japanese a307, how do I change the language to English please?
To be clear this is a pre owned unit - I’m looking at a settings menu that’s in Japanese
Edit - solved. PM me if you need help.
Jun 28, 2023 at 1:58 AM Post #3,340 of 4,198
Jun 28, 2023 at 4:37 AM Post #3,341 of 4,198
Google Services are not allowed in China and are blocked on Chinese devices.
There is no legal way to install it
Jun 28, 2023 at 6:39 AM Post #3,342 of 4,198
Still have 20Gb left
OK, so the error message makes little sense. I suppose it's possible that the Chinese version has a smaller System partition and the larger firmware simply can't fit. Sorry it didn't work out for you... I didn't have any issues loading International firmware on my Japanese version, but both already had Google Play.
Jun 30, 2023 at 5:17 AM Post #3,343 of 4,198
I use my player with the Ifi gryphon and really enjoy it I have taken up long walks and l am looking for something a little less bulky for this purpose.
Having also used the player on its own and enjoyed it I am on the lookout for a small amp to go with it.
I don't want a dac amp I want to use the Sony player dac and connect it to the amp.
Any recommendations.
Thanks.
Jun 30, 2023 at 6:48 AM Post #3,344 of 4,198
Thanks.
Rsa the shadow / pico slim / earmen tr-amp / vorza amp pure or due
