New Sony Walkman NW-A300 Series (Android 12)
Mar 22, 2023 at 7:59 AM Post #2,401 of 4,139
Mar 22, 2023 at 8:22 AM Post #2,403 of 4,139
I already had the case for my A105, but it fits perfectly on the A306, even the buttons line up. It may be a touch snug, but I actually like that.
Mar 22, 2023 at 8:36 AM Post #2,405 of 4,139
Edit:
This does not work reliably and probably isn't worth the effort (unless you enjoy frustration). Read ahead for more info.
For those of you with the low bass issue, I did finally figure out a workaround that resolves it, at the cost of losing sound adjustments. Simply disable the Sound Adjustment app using adb. Of course you can no longer use any of the adjustments, but I used "direct" anyway. Not extensively tested at this point. I do think this proves software versus hardware...
Mar 22, 2023 at 8:55 AM Post #2,408 of 4,139
I guess photos are the best way. A306 in miter case:
Mar 22, 2023 at 8:57 AM Post #2,409 of 4,139
That's excellent work there! Thank you
Mar 22, 2023 at 9:09 AM Post #2,410 of 4,139
Regarding the issue, I had the chance to run the test with a Japanese nw-306 but although the graph seems slightly different it still seems to have the issue (?). I still see that -10 right there for the Japanese version, can someone enlighten me, please?
UK version with the issue
Japan version:
any thoughts?
Mar 22, 2023 at 9:18 AM Post #2,411 of 4,139
Japan version:
any thoughts?
They both have the bass issue. Looks like the scales are a bit different.
Mar 22, 2023 at 9:30 AM Post #2,412 of 4,139
Wow thanks!, this is great news
You mentioned using adb
what was the name of the app/package?
did you use something like?
Code:
adb shell pm disable-user --user 0 <com.SOMETHING>
# OR  RATHER
adb shell pm disable <PACKAGEHERE>
I guess it can be obtained with something like this:
Bash:
adb shell cmd package list packages
but still wondered
thank you:L3000:
Mar 22, 2023 at 9:31 AM Post #2,413 of 4,139
Code:
# OR  RATHER
Bash:
but still wondered
thank you:L3000:
To disable:
Code:
adb shell pm disable-user --user 0 com.sony.walkman.soundeffectapp
To re-enable:
Code:
adb shell pm enable com.sony.walkman.soundeffectapp
Mar 22, 2023 at 9:56 AM Post #2,415 of 4,139
Remove the sound adjustment app didn’t remove the bass issue for me. :frowning2:.
I think i did something wrong here?
I could see the sound adjustment app icon disappeared from the home screen.
