Viper2005:
That which I have heard from Schiit Audio as well as others is that USB cables in excess of 2 meters should be avoided if at all possible, and that 5 meters is probably the upper limit in terms of high fidelity use...and Yes, I would love to run use a 7 or 8 meter length of it, (which would solve a host of problems). I would be happy to learn what is a "reasonable" maximum USB cable length used in conjunction with the Wyrd, though I have not found USB cables manufactured in excess of 5 meters...perhaps for the reasons stated above...thus my question regarding using the powered USB cable extension in conjunction with either the Cardas or the BJC USB cables I currently have used in my stereo system. Ideas, suggestions?
By the way, just a few minutes ago, on page 519, I responded to your previous response to one of my questions should you not have seen it...
From my experience both with computers and audio, the max length I would be comfortable with for a single USB cable is 10-12 feet before you need an extender/repeater, then you can add another 10-12 feet. The nice thing with the Ygg is that it will let you know if it thinks your signal is crappy, with the get-better-gear light on the far right If the light stays off, you are good!
