joeexp
- Aug 5, 2014
Believe us, you don't need AB for this kind of DAC. U'll know one day.
There are people who can help you-
Brought the Yggy to a buddy's house for about 4 hrs yesterday…
I've yet to power down my Yggdrasil, but someone I trust did and it regressed after being off for 30 minutes. I know it's a pain, but be best to give Yggdrasil the full warm-up again, to be sure, if you can.
The stage where the Yggdrasil can be described as "detail driven" is how I would describe it before it settles properly.
Hmm so I have at best a 30 minute window to change out amps and cables. That is good to know, for when I do comparisons.
you're funny
Had Yggdrasil in the house and turned on for 10 days. Spent some time this morning doing some "critical" listening - or at least as critical as I care to do - and the one word my wife and I agree describes the sound is "analog." It makes my digital rips from CD sound like vinyl. I am impressed.
My Yggdrasil is still in transit from LA to Frankfurt.
Thinking ahead: If temperature of the dac chips is really an issue couldn't that be solved quite easily with "DAC-heaters" being glued to the DAC-chips?
DAC-heaters could be build using constant current sources with BD139 transistors (or similar ones with SOT-32 case) which should fit from the size. A more sophisticated design could even include some thermal feedback.
What do you Schiit guys think?
I don't want to feed the trolls,
But my understanding regarding cable lifting (for audio) is that the air around the cables influences their performance and a cable on the floor would have part of it in air and the other part on the floor (wood, concrete whatever) - which creates inbalance...
If you go back to the theories that were developed back at the turn of the 18 to 19th centuries and exammine what electricity truly is and what the equations tell us, it paints a very different picture than what most have come to understand.
In short electricity doesn't exist within the wire but only exists at the junction of the electrostatic and magnetic fields, which occur outside of the physical wire.
I'll let that sink in.
There is more to it, obviously, but in essence the fields that surround the wires creates and influences the propogation of the voltage and current.
JJ
I forsee a lot of audiophiles being pulled over for speeding with their Yggy's in tow, "But officer, I'm on my way to a Head-Fi meet and I've only got 30 minutes to get there or my Yggy will revert to stock!"
Can someone who owns a Yggy comment on what sounds better USB or Toslink?
Thanks!
