EraserXIV
- Dec 5, 2008
The Rag uses a better switch, no reason the matching Yggy shouldn't. Hopefully the production version will have it.
I see two pairs of RCA outputs on the back. A question to anybody who has seen it in person: are they two separate pairs of SE line outputs? I don't want to assume and get my hopes up since the photo is too small to make out any labeling.
I'm really hoping the answer is yes. All of my amps are SE and it's amazingly hard to find good DACs with dual SE out. I've wanted to move up from my Channel Islands VDA-2 but I can't part with the convenience of its dual SE outs.
My phones are always playing now even if I am listening to my desktop Bose system which the LS50s and Rag will replace, but I can't hear them hanging on the stand because the Bose nearfield is so much louder, so this combined setup and my non desire to push past 90dB means I don't have to do any switching or worry about accidently blowing up the phones making input settings with the volume up.
However, if the headphone/speaker setting requires it's own gain setting too and doesn't map the best individual settings for each device, my life becomes a big pain in the ass compared to it's present simple carefree state with the Mjolnir. And I will be clueless as to the scenario where one would find any value in using the combined setting since the headphones would always be much louder than the speakers and more likely to get fried by turning up the speakers.
My new Rag is in queue for production. I've been reading the manual ahead of time to familiarize myself with it's operation. I'm trying to figure out why the default mode is set to output to both headphones and speakers at the same time. It would appear to be a very dangerous setting if certain scenarios are true.
I have LCD-X phones (95dB/mW sensitivity,1-4W optimal power). On my Mjolnir, I can't set the volume control above 10 o'clock before going to about "90 dB" on average which to me is much too loud and which hurts, and musical details are lost. I clamped my iPhone 4s mic inbetween the headphones and used my sound meter app to determine this number. My guess is the level I'm experiencing wearing the headphones is likely somewhat higher.
I have to assume that my in transit KEF LS50s (85dB/watt) would play much softer than this at the same volume spot assuming I could plug them into the Mjolnir.
It is unclear from the manual if the gain settings used for headphone only and speakers only transfer independently to their respective device on the phones/speaker setting or is a separate gain level chosen to run them both at the same time on that combined output setting. It seems to me that the former makes way more sense than the latter.
Since there is no separate indicator on the Rag to identify what device mode it's presently set to, one has to cycle through the settings at low volume and listen for which devices are active to determine this. This to me seems incredibly goofy compared to a simple set of 2 indicator lights (first on, second on, both on) The manual states that one needs to be careful while "blasting speakers" not to switch inputs suddenly to phones without turning down the volume or you'll have a very bad day. I understand that. If however the headphone/speaker setting maps the individual gain levels to each device rather than requiring a common gain level, there would be much less chance of a disaster.
I could see balancing the gain of each device so I would get a similar SPL at a particular volume knob setting. This would be great to easily A-B phones versus speakers on a particular piece of music since volumes are matched. Also it would be very difficult for me or a family member to accidently fry the phones by merely switching inputs while having too high a volume control setting since I would never need to change from the headphone/speaker combined setting. Neither device will ever go over my maximum comfortable level accidently.
Am I missing something here? Rag owners please enlighten me prior to it's arrival in 2-3 weeks.
**Commence Rant**
Just saw the back panel photo of Ygg and #&@^, there's that crummy little chrome power switch INBOARD of the cord socket!
I had figured (assumed? hoped?) that Ygg would have the same switch/fuse/socket plinth as the Rag which is one of my favorite features since it puts the switch ABOVE the socket and right at the edge of the cabinet. Don't think that's important? Try having your Schiit on a scheelf rather than a desktop, meaning you have to reach around rather than over. Unless you have the digital dexterity of a concert pianist who moonlights as a dealer in Vegas, that's a pain every time you use the unit.
Please, Jason, have mercy! if you can't go the whole plinth, could you at least put the switch outboard of the socket?
Not that I won't order Ygg the moment it becomes available, bit this is a bit like finding that the beautiful woman I planned to take to bed has a yeast infection.
**End Rant**
