New Questyle CMA400i
- Thread starter Bacon Bits
- Tags
- questyle
gibby
- Dec 18, 2006
Anyone interested in a bnib questyle qp2r?
Trade for CMA400i?
I wonder how this sounds with the Empyrean.
Probably quite nice, very firm and balanced sound from the CMA with really good treble extension to compliment the warm sounding Empyrean.
Amber Rain
- Aug 26, 2016
Hi just gauging opinion / thoughts on:
- Whether the CMA600i represents better value as it has been reduced to £850 at several outlets over the 400i at £730 (both new)?
- Whether my Shure SE846 would hiss with either?
- Whether I would be better off spending my money on upgrading my headphones (Shure SRH 840) to something else, rather than getting a headphone DAC/Amp combo. I'm kind of interested in Audeze LCD 2 Closed (can't do open backed headphones).
All of the above are currently outside my price range, but am clearing out / selling off some of my audio gear and maybe Santa will make a partial donation, but I want to use any funds wisely.
Thanks
Thanks
Pings
- Sep 10, 2015
Mine is having problems. It just discarded in Device Manager. I can't see the DAC in windows at all.
It wont show up as a playback device if you disable it, could it be that?
Pings
- Sep 10, 2015
It was Windows update (KB4471332) that I think knocked it out. I didn't disable it and it was gone even from Device Manager. I had to click "Show hidden devices", then uninstall it reboot and then reinstall the driver for Windows to see it again. This happened the other day when I updated Windows (KB4471332) and boom the DAC was not plugged in according to Windows. I couldn't figure it out so I just reformated. Then today Windows updated to (KB4471332) and again it was gone even from Device Manager. But, at least I figured out how to fix it.
Pings
- Sep 10, 2015
Spoke too soon. After a few hours, my speakers starting beeping and again it was gone from Device Manager. This time I could not use the method as it didn't work. After rebooting a few time it now shows up as XMOS DFU in Device Manager.
Does optical via your motherboard's onboard sound work?Spoke too soon. After a few hours, my speakers starting beeping and again it was gone from Device Manager. This time I could not use the method as it didn't work. After rebooting a few time it now shows up as XMOS DFU in Device Manager.
Pings
- Sep 10, 2015
I don't even own an optical cable. I'm taking it I need to get one to troubleshoot this thing?
It would definitely provide more info that's for sure. If it works via optical, then there's probably something wrong with the Questyle's USB input. And if it works there's a workaround too. If it doesn't worj, there's probably something wrong farther down the chain. Trying coax and/or using the preamp outs with speakers would tell you more too.I don't even own an optical cable. I'm taking it I need to get one to troubleshoot this thing?
crossfire
- Mar 6, 2007
Ended up purchasing this tonight to replace my sort of dying Liquid Carbon + Stealth DC combo. I hope this won't disappoint after reading all the positive feedback!
MaxD
- May 7, 2012
It is a realy nice class a Amp /DAC. not much to dislike. I replace my Schitt kit with it and its a bit of class. No analog in but I suspect that is intentional.
I have a question you guys might be able to help with:
I have had the 400I for about a year now, I have it paired with HD660s's and oppo PM3's, sometimes my fostex 50 mad dogs. Loving it still. But I need some advice:
I need to add a surface pro 4 as a source (input) It only has USB 2.0 and DisplayPort as digital outputs.
I am already using the 400I's USB in for my desktop so I need to use a coax as there are two or optical. I have used an old fiio x3 to convert from USB to Coax but that is yet another device between my source and amp.
Is it possible to get a clean digital audio from the display port connecter on my surface (or any other pc for that matter) ? Or a better way to convert usb to coax /toslink ?
Any ideas welcome.
Any ideas welcome.
JerryLeeds
- Jun 12, 2015
Only way I can see is a displayport to HDMI conversion cable and then an HDMI converter box with an output toslink/coaxial .. may not work with DSD
I've never tried the above
I wonder if there is a USB switch you can use?
https://www.amazon.com/UGREEN-Sharing-Peripheral-Switcher-Computer/dp/B01CU4QCRS
MaxD
- May 7, 2012
Now why dident I think of that. damn good idea!, I have a USB switch and dident think of it. I have just tested it and it worked briliently, about a 3 second switchover time.
Thanks man.
Thanks man.
