spookanide
Such are the woes of import duties. I bought it for about that much if I convert the price.My only issue with the cma400i is the price. Here in Norway the price is about $1187
Like others have said it is excellent with the LCD2. I was using a demo unit we have it was an LCD2 non razor. I thought the synergy was super strong... Full recommendation from me as wellJust found out about this amp and i looks awesome.
I use a pair of LCD-2F and are in the market for a new amp/dac.
Been looking at Schiit Jotunheim and deckard, but are now reading up on this.
How does it pair with LCD-2?
Thanks for the help. I guessed I missed that in the manual...was it in there?All 4 gain switches should be set the same, either all on high or all on low. If you set one on low and one on high on either the right or left channel you are 'unbalancing' the sound on that channel. The reason the gain switches are on the bottom and recessed is so they can be as close as possible to each amp channel electronics and so that they can't be accidentally moved.
Which of these 2 were you using to get a bunch of bass out of the high gain setting?Using Mr Speakers Ether Flow C and Westone4 iems.
Just tried it on the PS3. Can confirm I need to do this when I switch on the PS3 after using the CMA400i in USB mode on the PC. It's a total bug, thankfully a power cycle takes just tiny moment.It seems like when i switch from USB to optical, i have to cycle the power switch. Otherwise the volume doesn't seem to work properly.
Mr. SpeakersWhich of these 2 were you using to get a bunch of bass out of the high gain setting?
Hey,
I been looking all night and day trying to figure out if you can switch between headphone out and PRE out with this all-in-one. I am considering purchasing one but only if it allows me to use the PRE out for my active speakers and headphone amp for my headphones ( Individually ).
The all-in-one I have now mutes the PRE out once a headphones are plugged in. This works for me because I can choose whether to listen to my headphones without my speakers playing, or speakers playing without my headphones playing.
Can anyone help me out here? Thanks.
