piksnz
Balanced 2.5mm cable for Roxanne + AK240.
Where did you find the balanced cable with 2.5mm termination? Even I am looking for one.
^ it should not affect the mids and treble at least in theory as the pot is only applied to the bass signal wire which is completely separate from mids and treble. I think the dark sound people are experiencing about Roxanne is a combination of many factors. As far as I can hear, My custom Roxanne at 9 o'clock position on the bass pot and DX90 doesn't sound dark. It's quite neutral when I compare it to my JH16 which is now brighter and noticeable bump on upper bass.
Ok, that makes sense. Probably the people that are hearing it as dark are probably coming from JH13 or 16, which may have sharp treble, or other sharp treble monsters. It's also been said that the Roxanne is providing less details, but more impressions are coming in so, we'll see how people impressions differ.
My customs haven't arrived yet but I definitely didn't enjoy either the universals or AKR03. Not sure if it was a fit or tip problem but they were really dark and the bass sounded bloated. Hope the customs give me a different and positive SQ.
I have experienced this with the way tips were inserted. This was for TG334, and it was very senstive to fit. I had to get aftermarket tips and noticed if I insert it too much, the bass would get distorted( I guess bloat?), and the mids(specifically mids) would be buried behind. I know that fit will affect the sound, so customs could really enhance the sound for the better. I do notice tight bass with customs.
I hope so I had ro bury the tips in my ears pretty deep to stop them falling out, the universals are really big and the wires are heavy as well. The AKR03 do sound different from the universals, I felt they were tuned for more bass and were mid heavy. It could be they were newer and have less burn in. I never had the same problem with the UE18 or JH13/16 demos I tried 2 years ago but my ears have probably grown more finicky from all the decent gear these days.
I see why universals were a bad idea for these. You don't want so much weight for universals as they can easily shifted from movement. Since these are using universal tips, slight shifting could alter the sound significantly. With the 12 drivers, I can imagine these weighing alot and as you move, the driver weight tilting the tips downward, which isn't good.
I thought the 4 driver TG334 was bad in this regard as you notice the weight moving the tips outward over time.
I like the Shure universal designs as the weight rests on the bottom cup of the ear, and stays put.
This is one of the benefits to customs.
This is just pure speculation, but could the Roxanne sound a bit warm or with less treble(this has been reported lately) than their previous models because the pot is adding resistance in series to the monitors? For example, resistor adaptors are used, and usually they skew the FR and don't really exactly what they do, but they have been known to cut the treble, and add bass(not sure if this was the case, somebody correct me if I'm wrong)? Is the pot like resistor like the ER4S, but it's adjustable(which is what a potentiomemter does)?
I apologise on behalf of my auto-correct.
I understand that they're a commercial product but it CIEMs are unlike most other commercial products by definition.
How's this for an analogy:
You can buy a car sitting in a showroom and drive it away that day. However, you can also buy a car and add your specific colour, interior options, trim etc. but with that you would have to wait for your exact specs. Even then that stuff is stock, off the shelf at the factory. It's to be expected that if they had to mould the seat to your butt, that it would take considerably longer to deliver to you. :wink_face:
I was told you can only get the balanced cables with the AKR03, you can't even buy them as an option yet.
My custom Roxannes haven't arrived yet but I did audition the AKR03 and I'd like to get the balanced cable for the Roxannes. What options are available to get the standard cable as supplied with the AKR03 or a custom cable from a 3rd party?
