Arvan
- Jun 14, 2006
man..It sound really good even with the stock **** tubes and no burn in..Im very happy that i got this little thing
i'm thinking to replace the pot on my ld i+. any idea how to remove the knob? should i just pull it out? doesnt seem to come off easily. thanks for any hints!
Not speaking of the 1+ but knobs in generall.. Pry them off with care. They are usually just pressed on the axle of the pot. I usually use as big of a screwdriver i can fit behind the knob and gently pry it off. Pry from different sides so it gets loose evenly.
thanks guys for the directions! one more question if you don't mind: i'm thinking to get the alps blue velvet 100k logarithmic, i think the part number is RK27112, is that what i need? i know it's not a drop-in replacement and that i will need to use wires and all, just wondering if it's the right part to use. thanks!
You should be able to make that work. You'll likely need to grind down the spacer tab. I actually have one of those but haven't gotten around to putting it in because I messed up the PCB so bad putting in my RK16. Thanks for reminding me, I was looking for a project while I wait for some supplies to come in for something else I'm working on
thanks, i guess i'll order one and go from there. good luck with your projects!
Started digging into it today. It will be a very tight fit. The front to back pin spacings are different so I will be either bending over or removing all 3 rear pins and running wires to R3, C1 and L Input. I may have to insulate the pins as well if they are too close to the other components. Then I will use the PCB to mount the front 3 pins. I still can't find anything that would cause the hum in my left channel, so I might try swapping the sides of the ceramic valve sockets and see if that makes any difference. I also cleaned up some of the grounds just in case.
Yeah I tried testing it across the room since it is near my PC monitor, but it still had hum. I can only hear it on my NT6, which are very sensitive. It shouldn't be necessary to run wires from the front pins.i was thinking to run wires from all the 6 pins to the other side of the board, i think i've seen some pictures of this mod, probably in this thread but cant find them right now.
i don't have any hum, but i have a wifi printer close to where i keep the amp and when thats on i can clearly hear noise in the right channel. as soon as i turn the printer off, it goes away. probably a different problem, but thought i should mention it anyway, it seems like this amp is prone to all kinds of interference.
