boatheelmusic
- Dec 21, 2013
Jester, have you read your manual or called Grace?.......
Long before I bought the m920, several times.
Haven't bothered them about this particular question. I asked for user experience. I don't remember asking you, but since you're always here to 'help', what is yours? (I hope you'll sleep better seeing that 'I got one, I'm relaxing and enjoying the best')
Can somebody advise about the DSD filters? What exactly are they supposed to do and how it could impact playing back DSD64 and DSD128? I personally don't hear much of a difference.
DSD has increasing noise as the frequency climbs towards 100Khz - this could potentially upset some amps/speakers.
While I don't personally listen to dsd, I suspect if you had wide bandwidth amps you might want to use the lower cutoff filter or at least experiment. On the other hand a lot of amplifiers roll off anyway in that range, so maybe the higher cutoff filter would be ok. In any case there's not a big spread with the filters anyway, and I believe the filter characteristics are similar, so I'd expect any difference to be very subtle.
All the above is speculation on my part.
Yep. Been using the m920 as my preamp for about a year - may well be the best feature of unit.
I actually prefer the sound to the $3000 Jeff Rowland Capri preamp I was using previously - the m920 being more neutral/accurate IMO.
Sounds great with both my Odyssey Khartago and Halcro MC30 power amps
I only require 2 analog line inputs and because I use 2 power seperate power amps - for speakers and my HE6 headphones - the m920 really suits my preamp needs.
In fact I don't know of another preamp that provides similar independent volume/balance/mute functionality for two power amps. Some offer switching for 2 power amps but operate off a single volume control. I like having the independent volume controls as I like to switch between speakers and headphones when listening.
As you can see from my signature, I'm actually using the Schiit Yggdrasil as my main dac now, via the balanced input of the m920. I think the Yggy is a significantly better dac, but it probably needs to be as it's more expensive than the m920 and is a dac only (no pre function or headphone amp).
The m920 pre is plenty good enough to reveal these improvements - and other small system tweaks - while never actually sounding analytical or unnatural.
Anyone regularly using the m920 as a pre?
best,
o
