Sorry. I missed the replies concerning the filters.
Frans designed a Kameleon amp which I tried and tested with different filters designed for different headphones.
Basically, it's not a flat amp unless you put a 'flat' filter in. Frans has measured headphone responses and made a corresponding filter that gives the opposite shape so that you end up with a pretty flat response. The one that worked the best for me was the HD650 filter. In fact it was stunning. Sub bass appeared and the mid hump had been reduced, making the headphone into something really special.
The tiny filter boards will be made to fit before the Garage amps (Frans designed those as well) so that this same effect can be heard via the Garage series.
It takes the hd650 to another level.
The filters aren't available yet and Frans has a few of my headphones so that he can play around until he gets filters for them. That means for the more commonly used headphones, there will be an armoury of filters in order to help sort out fr issues that many seem to have.
He has quite a few filters designed already and they all really do improve the headphone sound a lot. The reason is that they target specific frequencies that he's measured on his kit that he uses at home to test headphones.
Hopefully, Jeremy will get finished units going for the amps and then people can sample a much more civilised sound from a variety of headphones along with that lovely tube flavour of the amps themselves.
I really hope it goes ahead. I was really knocked out by the Senn HD650 filter in particular. In fact, it pushed me to get a Fostex th900 because I missed the sub bass so much when it went back to Frans.
Come over to DIY Audio Heaven and nag them!!!
