supersmosh
Well...many people use Poweramp successfully with the Fiio m11 pro and I have not heard of any issues like that with Sony Headphone connect. Given that Fiio uses a modified version of Android and it doesn't operate exactly like phone versions, I would start there. I would suggest resetting the device to factory default, make sure all updates are applied and then start with Poweramp. If that runs normally for a day or so I would then add in the Sony app. and repeat the process. My "guess" is that the Lawnchair app is the culprit here. I have not seen it referenced in any of the Fiio M11 forums (I searched) or in any reddit discussions either but given the fact that it modifies the interface I would suspect that it simply does not play nice. Have you reached out to the app developer and asked if it is supported in this context?
Good
I'll have to give it a try with just poweramp. I tried it will all of my other apps except for lawnchair, and the bug still happened, so this is a good next step.Well...many people use Poweramp successfully with the Fiio m11 pro and I have not heard of any issues like that with Sony Headphone connect. Given that Fiio uses a modified version of Android and it doesn't operate exactly like phone versions, I would start there. I would suggest resetting the device to factory default, make sure all updates are applied and then start with Poweramp. If that runs normally for a day or so I would then add in the Sony app. and repeat the process. My "guess" is that the Lawnchair app is the culprit here. I have not seen it referenced in any of the Fiio M11 forums (I searched) or in any reddit discussions either but given the fact that it modifies the interface I would suspect that it simply does not play nice. Have you reached out to the app developer and asked if it is supported in this context?
Good luck!
I find this really odd, because I use the same apps on my other android DAPs(DX200, M7, M9), and they work fine.
