Do you guys turn off your Hermes when not in use? If so, how do you turn it off. I don't see any power button. Thanks in advance
you're not supposed to turn it off. just leave it on so the ocxo remains in an optimum state.
Thanks man. Youve been so helpful to me with my DDC. I cant thank you enough.you're not supposed to turn it off. just leave it on so the ocxo remains in an optimum state.
So basically if your DAC does not support I2S, the benefits of using a Denafrips DDC + MCLK would be minimal or nothing as trying to use one of the Digital Outs from the DDC like AES/EBU back to the DAC Digital Inputs of AES/EBU? Just looking for maybe an excuse to purchase a new DAC![]()
Hi,
I have a Terminator 2 and Lumin U1 mini.
What improvement can i get if i add Denafrips Gaia ?
^^^ This.Secondly, you can take advantage of the new clock out feature of the Termi 2. What I've found is, the clock out results in a turbo charging of clarity/detail and 3D holography (better, larger more well defined soundstage, imaging, instrumental separation).
Once you've spent funds at that level, it is a no brainer to get the DDC. You are not hearing your Termi at its best until you take advantage of the clock out and I2S input In my opinion.
Both the i2s (HDMI) cable and the clock cables make a difference. Depending on the music formats you listen to, you may only need one clock cable. I'd suggest you start with reasonably priced cables, get very familiar with the sound of your system and then later on, if your budget allows and you are still curious, try more expensive HDMI and clock cables and see if you hear differences.Is the clock cable must be better than i2s cable ? Or i just need to find better i2s cable , and just using canare 75 ohm bnc cable ? Thx.
If you are gonna high end like the Venus or better yet, the Terminator, then I think you should atleast spring for the Hermes. That device has been a revelation in my setup and I have the Pontus, so i can only imagine what it will do for better dacs. Alvin also recommend me the Hermes and said that that DDC should be more than enough for most users.I was considering a Hermes for my Venus II with possible upgrade to a Terminator II down the line. I have a Sonore OpticalRendu. Alvin recommended that I try the Iris FWIW.
