New Cavalli Audio Liquid Glass Amplifier - Fall Release
Dec 28, 2016 at 10:53 PM Post #766 of 794
  Just picked up a LG amp and loving it. Came with NOS 6SN7 tubes which I know are considered some of the best for this amp, but am eager to try more.
Anyone know what the best tubes are for HiFiMan HE-6 or Audeze LCD-3 headphones? They're very different sounding headphones, so jack-of-all-trades tubes may not apply.
It's a terrific amp indeed.
The best tubes I've used so far on the Glass are Mullard ECC32, which are expensive tubes. The gain on the ECC32 is higher, which also helps with the HE-6. Other tubes that work very well with the HE-6 are the 6SN7W Short Bottle. If you want cheaper nice quality tubes which have a good sound stage but sound a bit more solid state, try the Hytron (Pre-CBS) 6SN7. They're terrific tubes for the price.
For the settings, use this:
http://www.head-fi.org/t/621189/new-cavalli-audio-liquid-glass-amplifier-fall-release/660#post_11372925
If you were closer to SF, you couldve come over and tried a lot of my tubes.
Dec 29, 2016 at 4:31 AM Post #767 of 794
If you are bent on getting real Shuguang they imported by Grant Fidelity, based in Canada, but sell to USA direct. I was too lazy to see if they are still around. I have been no personal experience with the CV-181s but a very good friend whose opinion I trust, sold them shortly after they were conditioned, or as it is said burnt in.
Dec 29, 2016 at 10:55 AM Post #768 of 794
I am partial to Sylvania 6SN7s in general but own ECC32s33s and even a single B65. The other Englich tubes of note are CV 1988s made by Brimar which come in black and gray glass if you like that. I really like them but fear the market is"now flooded with counterfeits, thus in this case I recommend you buy decent used tubes.
The Sylvania I think you should consider beside the Ws which are superb, are the late 40s and 50s bottom getter GTs. Only buy really clean tubes which look feel orig box NOS if possible, not test 100%. Don't worry about the Bad Boy 3 rivet plate, but if within reach get them of course.
Aug 24, 2017 at 4:41 PM Post #769 of 794
Im curious - have any of you compared the good noval tubes like the 6922 (reflektor or cca) vs good 6SN7 tubes? Which ones sound better? Ive only always used ECC32/6SN7 tubes in my Glass, but curious about other kinds of tubes as well.
Sep 15, 2017 at 3:20 PM Post #770 of 794
I've preferred the 6SN7 to the 6922, though I did enjoy the Miniwatts. Seem to project better clarity and soundstage. The 12SN7GT tubes are excellent as well, they're often the same as the 6's but much more readily available and cheaper.
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
Sep 28, 2017 at 11:16 AM Post #771 of 794
cheeseeater, I've been meaning to reply to your question, it's just taken me a while.
The noise reduction could be external factors, but the tube also should get quieter.
When the tube is brand new there are still various contaminants on most of the parts. The general rule is that about the first 50 hours these impurities out gas from the heating and are captured by the getter. In about 50 hours most of this gunk is cleared out and the tube has a pretty hard vacuum. At this point the tube will quiet down and then improve for several hundreds of hours. At least for most tubes this is a typical process.
This just isn't for 'new production' tubes. I finally got the courage to open a never before unboxed pair of Delco branded Sylvania (i think) 6F8G tubes. You can tell they have never been opened due to the way they are sealed with a metal 'button' or 'stamp'. It would seem to be extremely unlikely one could actually open the box and reseal it as if unopened.
So here I have a brand new pair of beautiful World War II era 6F8G to use in my Icon HP8 MKII. Best sound I have EVER, EVER heard out of this amp, but, yes, upon warmup, there is a notable 'pop, tick and crackle' that diminishes with warmup and time. So, I would not worry about they noise :) Just enjoy as they settle in :)
Sep 28, 2017 at 12:53 PM Post #772 of 794
Would you be able to share more details of the miniwatts? Im trying to venture into different tube kinds to see if I like any more than the 6SN7s. So far my favourite pair are the 12SN7GT TungSol black glass round plates
Dec 15, 2017 at 2:38 AM Post #773 of 794
Dbel84, do you know what type of volume pot is inside the liquid glass? Mine was acting funky the other day. When I turn it just static and volume doesn’t change. Few hours later. Seems to work fine now but still a bit of static sometimes when turning.
I was thinking of replacing with same or a higher end one. Do you know the model or specs on the original? Thanks in advance.
Dec 20, 2017 at 1:55 PM Post #775 of 794
Sorry for delay. The clear Tungsol 12SN7GT with round plates happens to be my favorite, I wonder how close the black and clear are? I only found them once though. Mini watt isn't as good. You might try the russian 6H6N, it's a superb tube. Good soundstage, and really solid bass with a smooth midrange. D
Dec 20, 2017 at 2:27 PM Post #776 of 794
I'm not entirely sure if clear round plate tung-sols exist - Do you have pictures of these? The black glass ones are the same as the legendary 6SN7GT ones, except they're 12V.
I have recently tried the Siemens Cca tubes as well, and they're extremely good.
Apr 15, 2018 at 1:18 PM Post #777 of 794
Trying to understand correctly connections on the back of LG :
- source RCA output (CD player) goes to input 1 (or 2)
- L output goes to preamp RCA output
Is that correct ?
If it is, what happens when you don't listen to headphones (LG being off) and use source (CD player) to preamp and amp,
how do you get music, if output from source (CD) goes through LG, but LG is off since you don't want to use headphones ? I'm missing something…
Apr 15, 2018 at 2:59 PM Post #778 of 794
@quantx the manuals are online. If you go to Cavalli Audio, there is a link to the repair site: https://avensonaudio.com/cavallirepair/
Avenson Audio has all the old manuals linked there.
The loop (L) output is fed from whatever is input to the first (1) input.
The preamp (P) output is fed from whatever input is selected, and is variable with the volume. It cannot be used at the same as time as the headphone output, and there is a switch on front to select headphone (h) or pre (p).
There are two elements to having power on the Glass. First is when it is plugged in, and having the power switch in the back turned on. In this mode, the loop output will be on. Then once you power on the Glass via the front panel, (I believe) the pre-amplifier or headphone outputs will function.
Apr 15, 2018 at 3:03 PM Post #779 of 794
I know all that and have manuals, etc.
Still I don't get it :
- if I plug source (CD) to Cavalli (1 or 2), and Cavalli (L) to preamp, what happens when Cavalli is off (meaning power switch to OFF) and I want to listen source through pre+amp and speakers ?
Apr 15, 2018 at 8:05 PM Post #780 of 794
The pre-out is active, thus no output if LG is off through the preamp section. If you use the loop out, then the signal will merely bypass the amp.
.. dB
