TheMaestro335
- May 15, 2009
Hello all,
I got mine as well. They must have been reading this forum
Regards,
Jeff
Regards,
Jeff
I have had the same issue with it going silent, but I traced it to the cable (had to patch something together including the one they provided). I haven't had the issue since then, but I haven't had a lot of time on the unit.Hello,
I have received mine a few days ago.
I have installed the Xmos-USB-(Win10)-V4.130.zip driver (looks old...)
The device sounds nice (as far as I can figure out) but there is a big problem - it goes completely silent after just a few minutes (one song or so) and it only comes back after I switch it off and then back on.
Any of you have seen this behaviour? Burson is not responding on email - I wrote them 3 days ago and again, today.
Other issues:
- it gets quite hot during those few minutes of playtime
- when it starts, the output volume is lower than the displayed volume. For example, if I left it at 70 when I switch it on it shows 70 but it sounds quieter, like 50 or so. If I then change the volume just slightly to 69, it sounds like 69 should sound.
Thanks!
I can't speak for the people suffering from disconnects but personally myself it seems like a very out of date xmos driver.
The Microsoft driver works but as pointed out above is wasapi only.
The Microsoft driver also seems to have a higher latency which is visible in utube and twitch.
Bursons own driver is better on latency but does not support the advertised frequencies for the play or playmate.
