Fasterball
- Sep 30, 2016
I was using Audioquest Nighthawks - they aren't bright. I think I only had noise because I actually pulled the middle op amp out. Once I put it back in there was 0 noise. I have the v6 Vivid in the middle and because of an unfortunate shipping error I have V5 in the I/V and classic singles in the gain.Yes, this is correct.
LPF is Low Pass Filter - it cuts off high ( inaudible ) frequencies.
Normally a warmer OP-AMp is recomended here, the most common is OPA3124. Also the stock NE5532 works fine - if you have Basic version.
But I use V6 Vivid in LPF and I hear no noise. I've tested also V6 Classic and again no noise.
Are your headphones so bright or extremelly sensitive ? Because even when using sensitive IEM's I hear no noise.
