I have both Sound Professionals velour pads and Brainwavz hybrid.
SP velour didn't change sound much at all. Hybrid made ATH-M50 very bright sounding with very little bass.
Hybrid ended up on my modded T50RP(v2). Velour still used on ATH-M50.
Velour pads tend to reduce upper mids and treble response. Only if the pads are deeper or bigger in diameter should the bass response suffer. Brainwavz makes a hybrid pad of velour and pleather where the surface that touches your head is velour so you don't sweat and the rest is pleather so as not to effect your high end response.
In my experience, pads with a bigger opening improve bass response, not hurt it. Tighter, clearer bass, and still big and punchy. M50(x) sounds its best with HD280 earpads. It becomes very "analogue" sounding and natural, even more revealing, too. The big 10kHz treble peak in the older M50 becomes far more tame.
I was just going by my personal experience with a set of Pro4aa. Putting the ear further away from the driver reduced the bass response a little probably due to the way the phones were designed to work with the ear firmly pressed against the headphone.
I agree the SoundPro pads are quite faithful to the original signature, but they do tame the sub-bass and upper mid/treble peak - it's a slight difference but it becomes after switching back. The result is slightly smoother and a slightly wider soundstage. With these pads the M50x sounds a bit wider in soundstage than the MSR7 on stock, but it's mainly due to the M50x having some more reverb, and the MSR7 still wins out in the layering of the soundstage and instrument separation.
Unfortunately the Sound Professionals pads don't do a good job on the MSR7, and I suspect this is because the earpad flange sits a bit too loose around the MSR7 earcup (which is smaller than the M50). The sub-bass is rolled off, while the midrange becomes more prominent and you'll find yourself turning up the volume which makes it more peaked. On the plus side, the soundstage sounds much wider.
My Sound Professionals velour pads just came in, it looks and feels amazing.
However, I didn't think I would lose so much bass, the sound signature is very bright and little bass.
I'm disappointed by that I might have to try out the hybrid pad.
Just info, try Yaxi STpad for M50x.
I'm using it for MSR7. With MSR7, overall signature is same, only the bass is reduced (maybe just 1dB), so still maintain midbass impact like default earpads. My friend said STpad reduced the treble just little bit too but I can't hear the difference (because default pads is broken so I can't compare it directly).
And I ask M40x owner to tried STpad, he said to me STpad improve M40x SQ by reduced the bass and midrange more refined
The cons is not comfortable like HM5 earpads and twice more expensive than default earpads.
Hello all.
I'm new to head-fi and would like a few pointers that will guide my decision when buying a pair of headphones. I recently got into audio after falling victim to bling brands i.e, Beats by Dre, Skullcandy and ifrogz just to name a few.
I really like the look of Audio Technica's ATH-M50x. are they any good in terms of sound quality?
-Noahsam97
Edit: After a brief test in-store I can definitely say I made the right purchase.
Yay, a new M50(X) fan! I hope you enjoy them! Sorry I didn't have any advice for you. I still need to get the 'X' version.
What do you think of the sound? Is it similar at all to Beats headphones?(Some say it sounds like the Beats Studios.)
