Kingwa is monitoring the HeadFi threads today. He sent me a newer file to try to help with DSD clocking when using the U16. But does not help me with my U16 but sounds very good on PCM/DSD with the F1.
I went back and tried Asy3, P, P_2. PS_2, and the newer P2_dsdclk. The U16 no longer works with any of them! DSD with the F1 works with all of them.
Asy3 - Sounds good in retrospective look back, On hi-rez PCM files the OS 8x soundstage collapses slightly in comparison to the parallel firmwares. There is nothing wider that the width of my ears (headphones). At 192K OS 0x has more dynamics and wider presentation versus OS 8x. Is this correct? Don't know but always go by what sounds good or better.
PS_2 - The smooth version has a timber similar to Asy3. Seems like less grain too. The PCM image does occasionally go outside of the width of the headphones But adds to the experience for me. Still plenty in the middle.
P_2 and P2_dsdclk - After listening to PS_2 and Asy the added clarity and bass may be a little much. But nothing overdone. Smooth may be more balanced for your system. Bass is very tight, highs crisp with P_2s..
Here's the new R7 P2_dsdclk file if you are experiencing DSD issues over I2S give it a try. (
R7tda_Asy_P2_dsdclk.jic)
https://onedrive.live.com/?id=636DC4E8060D66A1!415&cid=636DC4E8060D66A1
