Tango Sierra
@DACLadder Do you have a photo of the orientation of the Accusilcons in the M7S? I know where they go on the board, just not in which order or which direction of the pins.
The Singxer SU-6 arrives today and planning ahead... What jumper switches are you using for AGD DACs if using HDMI I2S output?
Sw 1-4 set the pins where DSD Enable appear on the HDMI connector. Does not apply in my case.
Sw 5 is MCLK or WCK on I2S so set to MCLK (Off).
Sw 6 sets the frequency of MCLK 22M/24M (Off) and 45M/49M (On). It think 22M/24M is correct for AGD DACs so Off.
Sw 7 "can separately set the left and right channels in DSD mode of the I2S signals". Does this apply in my case using native DSD? Or is Off normal DSD L/R for our DACs?
Sw 8 sets clock phase of I2S BCLK where default Off has HDMI connector pin4 BCLK+, pin6 BCLK-. Default looks correct for PSA HDMI I2S.
Sw 9 sets phase of LRCLK where default Off has HDMI I2S connector pin7 LRCLK+, pin9 LRCLK-. This is opposite PSA method so set to On for pin7 LRCLK-, pin9 LRCLK+
Sw 10 sets phase of DATA where default Off has HDMI I2S connector pin1 DATA+, pin3 DATA-. This is opposite PSA method so set to On for pin1 DATA-, pin3 DATA+.
Looks like set Sw 9 and 10 On for PSA HDMI I2S standard. Leave others off. Not sure what to do with Sw 7 which may not even apply. Thanks!
On the Gustard U16 loaded 1.61 firmware today. Been using 1.4 PSA for the past 6 months. I still have the odd operational issues but 1.61 sounds really good! Amazing highs!
The SU-6 is going to have to be awesome to beat out the U16 soundwise.
The U16 I2S does sound great... when it works.
Really unacceptable to have to keep debugging playback issues. Want to spend time enjoying music and unwinding after work, not getting annoyed by static and rebooting equipment.
The SU-6 is a keeper for me, the next time the U16 throws a hissy fit it's going into the bin.
So could one replace the cheap external PS with a nice LPS easily ?The Singxer SU-6 arrived, connected, and works fine. I listened for about an hour and forgot I have to make a couple of switches to correct L-R and absolute audio phase!
Works great. Sounds really good. The external power supply is a $12.67 switching power supply (I found it online). But the SU-6 has fancy internal power circuits. No complaints about sound quality.
Let the burn-in begin again! (its getting old, really...).
@Toni-Mang You have a long way to go on the new Accusilicons. It is good though you comparing against a known reference. Week 2 on both my XO swaps was when the real magic began to happen.
Of course. The point is to avoid having high-freq noise injected into the electrical circuit.So could one replace the cheap external PS with a nice LPS easily ?
Hi,
Finally the V2 boards and the Accusilicon XO's are installed in my R2R-7. It took me almost two hours and power on was 20 minutes ago. I had plans on "pre-baking" the XO's before putting them in but times has passed since I ordered them and I am too eager... So first start was lucky (should be if You are careful and thorough). PCM works right out after the swops but DSD64 have noise but the noise is lowering during playing... DSD128 worked instantly (strangely enough..?)
Well, the journey has begun... with my new R2R-7
/Jan
ps. I will later swop the XO's in my 27.77....but for now I want to have it as a reference during the R2R-7-upgrade../J
