I am playing DSD with the Singxer F1 on IN6 and using the DA7 V2 DAC modules. No operational issues and sound is very good. Excellent bass, crisp trebles, and inky black background. I don't hear "birdies" when volume is pushed up. I tried DSD64, 128, and 256 and switched between sampling rates OK. My only complaint on DSD in general, and Kingwa is addressing in future Altera firmware, are pops when the DSD sampling or data rate changes. So use the volume control between albums or tracks.
First time I really listened intently to DSD. With the "Hoff Ensemble" test files (same tune at DSD64, 128, and 256) DSD256 definitely sounds a little better. More open and extended of the three speeds.
But I did not have the DSD 'birdy' issue with the V1 boards using the F1. So I switched to the Gustard U16 and repeated testing. DSD128 does not always want to play correctly with the Gustard U16. It's not "birdies' but gross robot sounding digital noise. DSD64 and DSD256 play OK. I can get the U16 to play DSD128 OK if I start and restart the track. I have a similar U16 issue with PCM where I have to start and restart tracks.
F1 seems OK but the U16 is suspect in my system and did not play well with the V1 boards as well. So looking forward to trying the SU-6 in the near future.
