New Audio-gd R-7, R-7HE R-8, R-27, R-27HE, R-28 Flagship Resistor Ladder DACs and DAC/amps
Jul 13, 2023 at 2:53 PM Post #10,461 of 12,026
Which last part :wink:
If you got your DI-20 close to the date of the last device firmware, flash V4.076. It made a gigantic difference for S/PDIF input on both my DI-20s.
Interesting, I just got the DI20HE ca. 3 weeks ago and was advised to install V4.075. Probably the older one, right? and I assume the "meow cat" version aka V4.076 was installed when sent out... BUT didn't work hence Jos adviced to use V4.075. no desktop pc but streamer, maybe that's why?
Jul 13, 2023 at 3:28 PM Post #10,462 of 12,026
I use r7he mk2 with external clock aune sc1pro (linear power supplied) and Rockna net as source through i2s. I know it’s really high quality sound. just r7he mk2 without clock outplayed Rockna wd signature by timbre, weighted sound, more layered in depth soundstage and micro dynamic…
With clock it’s on the same detail level now. But… which dac can be next step? May be someone passed this way earlier…
Did you try the DI20HE before the R7HEmk2?
Jul 13, 2023 at 3:42 PM Post #10,464 of 12,026
I think I don't need DDC in my system since rockna net has almost no noise and i2s connection to r7he
I think you are right here, but if you can try it for free I would! - spdif input ....What i2s cable do you use?
Jul 13, 2023 at 3:50 PM Post #10,466 of 12,026
unfortunatelly I have no opportunity try di20he without buy it... i2s cable is tubulus concentus
Ok I think you are already set. MSB Discrete may not even be the next step. Jump(try) to the Premier if you have good money.
Jul 13, 2023 at 3:54 PM Post #10,467 of 12,026
that was my thoughts from the beginning - I should make big money step up to gain in quality. Anyway it was 3 options on my mind but I'm not sure it's upgrade - cen.grand dsd dac 1 and holo may lv2/kte or aqua formula
Jul 14, 2023 at 4:34 AM Post #10,468 of 12,026
I just saw the NET has usb! - you should definitly try the DI20HE with USB. Return it within 14 days, money return. Arrange it with a seller Im sure you will have the opportunity.
DI20HE gives the separations more authority. With the Tubulus cable(to R7) I can only imagine how great it will sound!
Jul 14, 2023 at 4:42 AM Post #10,469 of 12,026
in stock Net usb is just for external HDD....
Jul 14, 2023 at 4:43 AM Post #10,470 of 12,026
Hmm but it has a output?
