New Audio-gd R-7, R-7HE R-8, R-27, R-27HE, R-28 Flagship Resistor Ladder DACs and DAC/amps
Jun 24, 2022 at 5:55 AM Post #8,761 of 12,020
This forum is not helpful to those trying to find the right gear.. For problem solving, yes.. but not for exchange of impressions.. there is virtually nothing here.. That's my honest opinion.. Will be looking for answers elsewhere..
Jun 24, 2022 at 6:24 AM Post #8,762 of 12,020
I need no charity.
How many do you think have both R8HE Mk2 and R7HE Mk2 of those who are members here?
Btw with your attitude you will not get more people who want to help you.
Jun 24, 2022 at 6:35 AM Post #8,763 of 12,020
There is plenty of people here who use either R8HE or R7HE in either NOS or OS mode.. The question was which mode is more preferred statistically? You don't need to have both devices, to answer..
Since nobody replied, are you suggesting that I will get a worse result after I have expressed my frustration? Less than nobody? )
Jun 24, 2022 at 10:45 PM Post #8,768 of 12,020
Just got the R8 MK2. Looking for a good HDMI cable to use for it. Does anyone have recommendations preferably under $100. Fine with buying off of aliexpress.
Try searching within this thread around a month ago. Members here just talked about this topic. I'm sure you will get a nice one within the budget.
Jun 25, 2022 at 1:04 AM Post #8,769 of 12,020
Jun 25, 2022 at 6:32 AM Post #8,770 of 12,020
Hi all ,, long time since my last post ,,
Looking to explore external clock and i am eyeing the (AfterDarkClayX GIESEMANN OCXO 10MHz Reference Master Clock) but it has one output ,, my DAC (R7) has stock master clock input which i guess is 50ohm ,, but my DI20HE has 75ohm input ,, so which one i should use the master clock with ? the DI20HE or the R7 for best results ?
i only use the I2S cable and i mainly supsample with HQP or audirvana to DSD
Jun 25, 2022 at 6:41 AM Post #8,771 of 12,020
I can tell you what I did. Saved money and purchased the Trifecta Extreme Edition, double Emperor if I remember correctly, which has several outputs. This is a good investment for the future, being able to clock several components at the same time regardless of their impedance. Definitely worth it.
Jun 25, 2022 at 7:08 AM Post #8,772 of 12,020
Thats a 3100$ clock ,, i never tried any clocking before so i guess this is too steep for me
Jun 25, 2022 at 9:22 AM Post #8,773 of 12,020
I highly recommend you to start with Morion clock and you can invest in higher level of clock if you like it. You should not buy blinded for that price tag.
Search "morion" in this thread. You can customize the number of output and choose between 50 and 75 ohms (of eaxh port). Many direct impressions by members here which is really helpful.
Jun 25, 2022 at 10:13 AM Post #8,774 of 12,020
With the latest fw, the difference is very small, having the ext. clock feeding the di20 or not, while feeding the r7 makes of course the most difference, as always. FIY, Afterdark makes a 3 output unit, which can be costumized to have both 75 and 50 ohms outs.
Jun 25, 2022 at 12:47 PM Post #8,775 of 12,020
I got one of these (DI-20 to R7Mk2) and it‘s spectacular value for money. One my friends then got one for his M7S - Singxer SU1 combo and he loves it too. When I ordered I just put Audio GD in the comments and one turned up.
Credit to @FredA for finding this gem.
The credit goes the person who posted first about this awesome cable, which was not me. But i sure recommended it many times.
