Guys, I finally made my r8 to sing, with whatever music players, DSD plugins or DSD files (in native).
It does sing beautifully though I still found hard to tell the difference between NOS and OSx8 which the later gives more details but I feel bit unreal.
The key to make it work, with all kinds of DSD (64, 128, 256, 512) is to have the right firmware for both USB interface and the decoder (FPGA).
Mine is r8 2021 version which has a different built in clock, USB and HDMI interface. This leads to two thing: 1) Any older than Dec 2020 FPGA firmware will not work. 2) Even with Dec 2020 firmware, it will NOT work with DSD files if the USB interface firmware is not the "CPLD_1081_SWAPPEDSD" and the corresponding CPU firmware. If
@sajunky you happen to have the CPLD_1080 firmware flashed along with any FPGA newer than Dec 2020, and you have r8 2021, you'll ALWAYS have issue playing DSD files in native format. The reason is the way USB transmit information and the async mode which is not supported in CPLD_1080 firmware (I guess). By the way, the original r8 never works with r8 2021 firmware, so it will also break down if you've flashed newer firmwares.
Hence, I reckon r8 is good for its hardware, but Audio Gd definitely needs to update its website for the latest USB interface firmware and encourage its customer to upgrade.
Mystery busted!
