FredA
- Dec 15, 2013
I would be probably better to use a pci hdmi i2s card like @Whitigir uses directly and avoid usb all along.I'm close to ordering one of the following combinations:
1) R28 + pair of Precision 3s (well within my current budget)
2) R28 + Master 3 (will have to use some credit)
3) R8 + Master 9 + Master 3 (will have to utilize a fair amount of credit)
I'm leaning toward combination 2) at this point, as the speakers I'm getting aren't going to be the most efficient, though the first combination would later make for a great bedroom system. I eventually want to get an the R-7HE, an HE-1 (and Master 9), and a pair of Master-2Hs, so perhaps it's silly going for the third option now. On the other hand, it may be a good long while before I can afford the flagship units. Hmm, I say.
That aside, regardless of which Audio-gd I end up with in the short-term, I'm thinking of using one of those JCAT FEMTO USB cards to output the bits from my computer. I wonder if any regular viewers of this thread have tried that card. I know it's generally frowned upon here, but I'll be using my Mac Mini to play my files. The Mini will be connected to an OWC Mercury Helios 3 Thunderbolt 3 PCIe expansion chassis, which will house the FEMTO card. Initially the card will be powered by a LPS from iFi, but later I will likely try the HDPLEX 200W unit to power both the JCAT card and the Helios 3 unit as well, forgoing the included SMPS for that enclosure. To begin with, I'll be getting my R28 or R8 with the Singxer F-1 card, and later I'll add something like that new Singxer SU-6 to the chain (and go I2S).
