FredA
- Dec 15, 2013
Emphasis added is mine around how I based my recommendation.
This is a bit OT for the thread, so I'll stop here, but feel free to PM.
Fred can make a recommendation perhaps on a card to work with your laptop. I don't have any I'd recommend, sorry. Either way, unless you're comfortable opening your laptop, installing the card, installing drivers and troubleshooting, I would not recommend that.
re: building your own Pi-based player. If you understood what Fred meant by nodes and packet loss etc. etc, then you could try building. If all of that was hard for you to understand, then stop here. DACLadder's post may give you an idea that even experts with the help of an expert have problems with these sometimes. If you are not into tech issues (your words) or don't understand his or Fred's post, then I don't recommend it. I also have no idea if any of these solutions work with Dirac.
I thought you were asking if you could install an "dedicated" OS on your existing laptop, if that would help, and for alternatives/recommendations based on your skills and use case. I also tried to explain a bit about OSs. Apologies if I got that wrong.
Summary:
What else?
- Can you / should you install a new "dedicated" OS on your notebook for audio? No. I'd very strongly advise against that.
- Is there anything you can do with your current notebook? You can try some other audio software that runs on Win10. Not ideal, but the cost is the lowest (free in a lot of cases to try). If MQA on Tidal is relevant or important to you, look for software that supports it. You already have a lot of things to go between your laptop and the R-8.
Hope that clears up my recommendation based on what I thought you were asking and my perception around your level of skill and needs. Sorry if I've caused confusion.
- If you want to buy a dedicated PC-type product (that works with Tidal and Dirac) to use instead of your notebook - there are many choices. Look up the NUC family of devices for a starter of what those look like.
- You can try a Mac Mini or some other devices.
- Don't try to build a pi-based device unless you're comfortable. The ones suggested above likely won't work for you unless you're willing to give up some of what you said was important to you and if you have some technical ability. If someone can tell you how to run Dirac on a pi - awesome. If you do try it and are willing to make some compromises... YouTube and forums are your friend.
Most importantly, enjoy the R-8!!!
If very lucky, someone can setup a standalone player with Volumio without any issue. Or a upnp node. But as you mentioned, there is some prerequisite knowledge to have to help minimizing the fuss. On the bright side, using just a pi and an ebay lps will cost around 200$, so there is not much risk financially. What you risk the most is loosing your tempter. But the reward is worth some pain coming from a mac mini. I get such great sound pretty much every night now.
